Go to Post Remember, the song is FIRST and the competition. We are the group. We dance to FIRST, we move because of it. - Joe Matt [more]
Unread 13-01-2007, 20:55
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: pneumatic actuator for storage tank
Originally Posted by ngreen View Post
Take that as you will. Anyways you would only be able to store air at 60psi because a actuator would have to be downstream of a pressure regulator.
You would also have to run it through a solenoid, and have your exhausts hooked back into the pneumatics system. Just be glad they're letting teams use 4 tanks this year .. 2 is not enough.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Different Air Storage Tank? Jess1513 Pneumatics 5 09-02-2005 09:22
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Pneumatic Actuator limit? Moshingkow Rules/Strategy 4 08-01-2003 02:16
Electrical Connector For Climate Control Actuator gail OCCRA 3 20-10-2002 23:20
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
