Go to Post Wow... no duct tape? - Stormnnormn [more]
Unread 13-01-2007, 22:20
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Who has the tidiest wiring?
Post a picture of what you think is the best wired robot
Team 2200:
2007 rookie year, 5 days after kickoff.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 13-01-2007, 22:27
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Who has the tidyest wireing?
You wiring is pretty tidy. But I would say you should do something about that drive shaft just floating there. You should probally put in a bearing block there.....
Unread 13-01-2007, 22:29
Bochek's Avatar
AKA: Adam Bochek
in the works.
Unread 13-01-2007, 22:31
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
do you plan on driving all four wheels? Those kit wheels are pretty grippy and it doesn't look like you'll have an easy time turning.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 13-01-2007, 22:40
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
im going to do basic wiring hopefully tomorrow
i will post a pic then
/forest
Unread 13-01-2007, 22:41
REVving up for a new season
FRC #2848 (All-sparks)
Some of my favorites from past years...
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-01-2007, 23:01
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Greg, do you know what that black (plastic?) material is in the first pic? Where do you get it? What are the specs, thickness, weight, etc.?
We have always used plywood for our electronics board because it is cheap, easy to cut and screw stuff to and also non-conductive incase someone makes a mistake and drops a screw/wire/etc. I would like to try something new and lighter this year. Does anyone have a favorite material they can recommend?
Unread 13-01-2007, 23:05
Judging by the background, I'd say you might want to ask 254. The fact that there are 2 indicates a second robot--also pointing to 254. Then again, I could be wrong.
Unread 14-01-2007, 00:05
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Where are the labels?
Unread 14-01-2007, 00:36
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Re: Who has the tidiest wiring?
Team 2200:
No DIN Rails?
Eat, Sleep, Build Robots
Unread 14-01-2007, 04:00
AdamHeard's Avatar
Lead Mentor
Since you guys are not powering the front wheels, you should probably swap them out for something with less traction.
The Andymark 6" Omnis would work well.
Also, the rules aren't exactly clear, but it looks as though the DIN rails are required. Check the best practices and the electronics manual linked under section 8 of the manual on the usfirst site.
Also, those panels posted above with the white wires are 254's.
Unread 14-01-2007, 05:23
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
1/4" ABS Plastic is what you see there. Available pretty much anywhere. We got ours from McMaster. It is about the nicest, lightest and easiest thing we have found to work with. Everything else is either too heavy, too thick, or too ugly for our tastes.
Here are some more pictures for ideas and inspiration. There are plenty of better examples out there, too. I have always been inspired by teams 60 and 207.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 14-01-2007, 08:11
Bochek's Avatar
AKA: Adam Bochek
We are swapping to 4wd, just waiting for the parts to arrive.
-Bochek
Unread 14-01-2007, 11:17
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Those wires right in front of the Victor fans really worry me. With as little airflow as that last victor would get, magic smoke may make a debut.
KK4KQO
http://voltair.us
Unread 14-01-2007, 11:36
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
My favorite material to use is fiberglass balsa wood composite board. It's very strong and durable, and very very light. The only thing that I don't like is that its very easy to strip out a hole and you can't really nail anything to it. We were going to use carbon fiber balsa wood composite board in 2005, but carbon is well... conductive, so we quickly changed that idea .
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Who has the camera working? cvbritton Programming 43 28-01-2007 13:46
who has the best eric195 General Forum 4 25-03-2004 16:13
Who has the coolest avatar? Alex Cormier Chit-Chat 35 06-02-2004 18:19
Who has won in the past? Petey Website Design/Showcase 5 02-02-2003 23:52
Who has the best computer? James Crivellone Chit-Chat 59 12-03-2002 20:34
