Go to Post The only way you can be undermined is if you let yourself be undermined. - DUCKIE [more]
Unread 14-01-2007, 01:21
NK2007 NK2007 is offline
662's Manipulator VP
NK2007 is an unknown quantity at this point
Re: pic: Bike Cim + 56 mm gearbox
Originally Posted by Caleb A. View Post
When i imported both assemblies into solidworks i had to remate all the parts of the motor and tranny, did you have the same problem? Any ideas on how to aviod this problem? This could save me some time later on in my designing, for example, the victor speed controller imports as like 60 separate parts and i dont want to have to go thru and remate all of the parts.
Hmm, this was done in inventor, so im not sure about solidworks. Someone else may know?
Unread 14-01-2007, 03:14
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
step files are your friend
Unread 14-01-2007, 10:35
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
I had this problem when using Inventor. i fixed it by leaving the motor/gearbox assembly as is, and just using that assembly as a sub-assembly of the main robot assembly. This works because you can't move the parts inside a sub-assembly, even if they are not mated.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 14-01-2007, 16:46
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
I would avoid leaving parts unconstrained because I don't know what would happen if someone else tries to use the files, or if the animation team would import it into 3dsMax. I could be wrong; maybe the parts stay in the right place.
If Solidworks lets you do this, at least ground all the assembly parts. In Inventor assemblies, parts can be grounded, which means that they're locked into a certain position relative to the origin and axes.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 14-01-2007, 23:42
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
In Solidworks terminology, you select "Fix" for the part. To unfix the part, select "Float."
Unread 15-01-2007, 01:10
Most step files come without any mates in them. As said above, just fix the components to keep them assembled how they came.
I then make a new assembly and put the transmission in that new assembly. That way, I don't have to deal with the fixed components in my new assembly and can easily drop another of the transmissions in a different assembly without much work.
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
pic: BIKE NYC! Rich Wong Extra Discussion 5 12-05-2006 13:17
New Model Posted - Mini Bike Motor Ed Sparks Inventor 0 18-01-2006 23:03
Poll: CIM vs. Bike Motor? Swan217 Motors 18 14-01-2006 13:02
Gearbox that can be used inline with a CIM bombadier337 Motors 3 11-03-2005 22:05
