Go to Post These two options can both be used effectively to create a wonderful experience for the students, but limiting them to one area is like taking a globe, slicing it in half, and saying, "You can only explore this half." - Alex Golec [more]
Unread 12-01-2007, 12:07
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
Herding multiple tubes
While I understand that the robot may not be in possession of multiple tubes, possession of a tube on the ground is defined as being in contact with the robot at more than a single point.
That said, what are your thoughts on grasping a ringer and using it to herd other tubes. In that way only one tube is touching the robot--other tubes would be touching the first tube.
(I know -- difficult to acheive perhaps, but just curious as to your thoughts)
Unread 12-01-2007, 12:21
Re: Herding multiple tubes
Pushing a tube on the floor with one you are holding is definitely against the spirit of the rules, if not the letter. If I were in charge, I would proclaim that a "possessed tube" is an extension of the robot. Using one tube to herd another tube would violate the "no multiple possession" rule.
Unread 12-01-2007, 12:23
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
In the past, FIRST has ruled that any object in the possesion of your robot becomes a part of the robot for the purposes of determining contact. (ie. you can't use a scoring piece to push high up on another robot and then claim that you wern't pushing them, you were pushing the scoring piece). I think the same ruling would be made in your example.
Unread 12-01-2007, 12:26
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Doesn't G09 apply?
<G09> POSSESSION - ROBOTS may only have 1 (one) GAME PIECE in their POSSESSION at any time during the match. Inadvertent bulldozing of GAME PIECES while the ROBOT moves around the field is allowed. Controlled "herding" of a single GAME PIECE lying on the floor is permitted as long as no other GAME PIECE is in the POSSESSION of the ROBOT. Herding of multiple GAME PIECES, or herding of a GAME PIECE on the floor while in POSSESSION of another GAME PIECE is not permitted (as this would be considered POSSESSION of more than one GAME PIECE).
Because aren't you in possession of one and using it to herd another tube?
Unread 12-01-2007, 13:12
I agree that it is probably in violation of the spirit of the rules, and this actually isn't a strategy that has even been discussed by my team--just something that came to mind while reading one of the Q&A responses.
As far as being in possession of more than one game piece--as the definitions currently stand,
POSSESSION -- ...A GAME PIECE on the floor is considered to be in the POSSESSION of a ROBOT if it contacts the ROBOT at more than a single point.
ROBOT -- anything that has passed ROBOT inspection that a TEAM places on the field prior to the start of a match.
By those definitions, the game piece is not a part of the robot and thus pieces on the floor being pushed by another game piece would not be in the possession of the robot.
EDIT -- OK, Robby, I see your point, where herding is not dependent upon possession or its definition.
Unread 12-01-2007, 14:43
BillP's Avatar
BillP BillP is offline
AKA: GreenBeard
None #0624 (CRyptonite)
BillP is a jewel in the roughBillP is a jewel in the roughBillP is a jewel in the rough
Yes, all of these are valid points, but I can (almost) promise you that every referee will interpret herding ringers with another ringer in your possession as possessing two ringers.
I know that I would.
Unread 12-01-2007, 14:49
Robby's Avatar
AKA: Kevin Beranek
That's why I quoted G09, herding has nothing to do with the definition of posession, and I would define what was proposed above as herding. Notice the part that I bolded.
Originally Posted by Robby View Post
Doesn't G09 apply?
Unread 13-01-2007, 01:01
Electrical Engineer
Rookie Year: 1995
All,
Please read Team Update #2. This has been resolved by FIRST.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 14-01-2007, 08:07
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
What if you have a ramp/lift bot and you need to clear away any stray toroids before you can use your ramp/lift? Would that be considered herding if you are just getting them out of your way?
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 14-01-2007, 10:48
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
What if you put a negative charge on the tube and your arm. Then you could push them around without touching them. lol
Unread 14-01-2007, 11:32
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
I think that would probably fall under "Inadvertent bulldozing".
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
Unread 14-01-2007, 17:11
I would have to disagree. If you are trying to move them out of the way, how is that "inadvertent?" Game pieces in the home zone may be a big issue in this challenge.
Unread 14-01-2007, 21:20
NoSkaOnTheRadio's Avatar
NoSkaOnTheRadio NoSkaOnTheRadio is offline
Team 1757 Alumnus
AKA: James Carney
FRC #1757 (The Big Green)
NoSkaOnTheRadio has a spectacular aura aboutNoSkaOnTheRadio has a spectacular aura about
Send a message via AIM to NoSkaOnTheRadio
this makes me think of how the dynamic of gym class dodgeball changed completely when we discovered a player could deflect and incoming ball with the one in his hand!!!
i personally think the proposed strategy would be against the spirit of the rules, and i'm glad that FIRST clarified it.
i am still concerned about inner tubes being placed in the opposing alliance's home zone to mess up their end phase. i feel like this would be inefficient and underhanded, but not very difficult to achieve. would anyone seriously try it as a strategy?
Unread 30-01-2007, 03:20
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
http://forums.usfirst.org/showthread.php?t=1661
its clear now that if you were a ramp/lifter bot, you could clear away the area and not have to worry about the herding rule.
hoped this was helpful
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
human player interaction with tubes stuntman551 Rules/Strategy 19 17-01-2007 15:13
pic: Vex-sized tubes for Mini-FRC! Jessica Boucher Extra Discussion 4 15-01-2007 19:32
How to measure pressure in the tubes? Nitroxextreme General Forum 8 13-01-2007 19:10
<G09> Dropping Tubes on Your Opponent Jimmy Cao Rules/Strategy 43 10-01-2007 12:26
Sitting on top of tubes notquitehere188 Rules/Strategy 23 08-01-2007 02:03
