Go to Post This is the first (and, if this stuff keeps up, last) time FIRST has allowed high-speed projectiles in years. Please use some common sense, people. - Madison [more]
Unread 14-01-2007, 10:26
itzrobz itzrobz is offline
None #0333
itzrobz is an unknown quantity at this point
Camera Help
LabView is unable to find my camera, but i am able to upload code to it. What could be wrong?
-Programming Cable is Connected to Camera
-PWM1 and PWM2 are servos pan and tilt, respectively
-The TTL chip is connected to the RC.
Thanks for your time.
Unread 14-01-2007, 11:12
Re: Camera Help
To use Labview with the camera:
- Connect the camera directly to the PC via serial cable.
- Connect the camera power only to an RC PWM, analog or digital pin.
- Do not connect the camera to the RC TTL port.
- The RC and OI must be powered up and communicating.
- The camera must be switched on
You can have either Labview or the RC controlling the camera but not both at the same time. Trying to only confuses the camera since it doesn't know who to listen to.
Unread 14-01-2007, 11:22
None #0333
Re: Camera Help
The Camera Servos are connected to the RC. If i wanted to control those servos would I have to connect Camera or the RC?
In order to read the Camera output, would i have to combine the FRC code and the Camera code or upload the FRC code to RC and Camera code to camera?
Unread 14-01-2007, 11:28
Re: Camera Help
We only download our code to the RC not to the camera. That code in the RC handles setting up the camera.
We can send commands directly to the camera through Labview or a terminal emulation program on your PC to play around, but in competition we'll only be working through the RC code.
Labview cannot be used to test drive the camera servos with this year's model of the camera. It can play with the other camera controls, and help you focus the camera lens.
To run the camera with the servos, then disconnect your PC from the camera and connect the camera instead to the TTL port on the RC.
There are two ways to program your RC 1) MPLAB 2) EasyC.
For MPLAB download Kevin Watson's camera code from http://kevin.org/frc/, specifically start with http://kevin.org/frc/frc_camera_2.zip and use IFI_Loader to download the enclosed hex file to your RC.
For EasyC o to http://www.intelitekdownloads.com/easyCPRO/ for the code and post specific questions about it on this CD sub-forum http://www.chiefdelphi.com/forums/fo...play.php?f=155
Unread 14-01-2007, 11:30
None #0333
Re: Camera Help
That would mean I would have to combine the camera code and the FRC code and upload them to the RC?
Sorry, I am new to this.
Unread 14-01-2007, 11:47
Re: Camera Help
Sorry to throw so much at you.
Yes, you'll need to combine your code, but start with just the camera code to make sure you figure out how that works first.
Start simple and build up.
Unread 14-01-2007, 11:52
None #0333
Re: Camera Help
Alright I understand what to do. Thanks for the help.
Unread 18-01-2007, 16:13
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: Camera Help
How does the connection of the camera for the Kevin's MPLab Camera code go?(or in simple english, how do I connect for he MPLab CMU code?)
Unread 21-01-2007, 10:36
None #0333
Re: Camera Help
you upload the code to the RC. ONLY the PWMs and the TTL should be connected from the RC to the Camera
Unread 22-01-2007, 08:05
AKA: Nir Levanon
Re: Camera Help
Ok, wait. We had the camera working with LabVIEW. We're supposed to connect the camera to the TTL, the RC to the comp', pass the MPLab camera program to the RC and then take out the TTL, connect the CMU to the comp' and then use LabVIEW to calibrate?
If so, how?(and please don't send me to even more manuals, I try to read them but evantually I barely understand what they tell me to do ).
Unread 22-01-2007, 08:31
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: Camera Help
Once you load the program to the RC leave the TLL connected to the camera so the RC knows what the camera is seeing. You only need to have the camera connected to the computer to calibrate it. Hope that helps a little.
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
Unread 22-01-2007, 10:11
AKA: Nir Levanon
Re: Camera Help
We loaded the program, it worked once(found the light), but the servos didn't move. Then we realized that we put the camera power and the Servo PWM cables to the Digital IO . We fixed it, put them all in the PWM output, didn't work. Put the power in the Digital IO. Didn't work.
What now????
Unread 24-01-2007, 11:38
None #0333
Re: Camera Help
What now????
SERVOS get plugged into the PWM.
As for the Camera Power, if PWM dont power it try plugging it into the Analog, thats what we did.
Unread 24-01-2007, 11:47
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Camera Help
I also recommend using the Digital or Analog outputs to power the camera. To make the servo's move make sure you have your backup battery charged. You can check to see if the OI is reporting low backup battery.
Unread 24-01-2007, 16:41
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Camera Help
Perhaps I'm totally ignorant, but why do you continue to advise teams to do this?
-Kevin
Kevin Watson
http://kevin.org
Camera HELP! yarb65 Programming 5 29-01-2007 21:58
Camera help needed bluisnake Programming 9 08-08-2006 14:58
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
camera help! |20807 61|2|_ Programming 5 08-01-2006 14:44
camera help needed Anton Programming 0 17-02-2005 06:52
