Go to Post Who doesn't love a good Finger Lakes Regional?! - LeelandS [more]
Unread 14-01-2007, 13:50
Billfred's Avatar
Billfred Billfred is offline
Lexan side panel thickness?
I'm still investigating a few things for this year's robot, one of them being protective side panels for the robot's frame (which will be kitbot, if that helps you visualize it). We're investing in a pair of AndyMarks this year, and I have this recurring fear that those gold side plates will become a big "HIT ROBOT HERE" sign. (Sort of like how your feet always get stepped on right after you buy a new pair of sneakers.) In the interest of giving the sponsor logos the same protection (except theirs would be more "SCRAPE ROBOT HERE"), I'm looking at lexan for this particular job.
For those who've done similar things before, what thickness of lexan were you using? Did it hold up reasonably well?
Unread 14-01-2007, 13:54
Nate Laverdure's Avatar
FRC #2363
Re: Lexan side panel thickness?
We have used 1/16" for places where the lexan has been supported by the robot's frame behind it in case it gets hit, and 1/4" or larger where we need some support.
Both thicknesses have never been punctured on our robots, but they get scraped up pretty well.
Unread 14-01-2007, 14:27
Andrew Blair's Avatar
FRC #0306 (CRT)
As long as it's properly attached and supported, Lexan as thin as 1/16" may protect you. 3/32 or 1/8" is a safer bet though. I would not recommend using anything thicker than that unless it is really unsupported, or protecting something that's gonna be chewed on. The weight penalty is not necessary, as something thinner will do the same job. More often than not, you'll see the lexan pull, deform and bend instead of simply breaking, and if the shield fails, it'll be because of attachment failure. We've bent 1/4"-20 bolts 90* while the Lexan mostly deforms around the bend.
It's hard to make it really fail. Although, as said before, it will get scratched up as time wears on, but almost entirely it will be due to robot contact, not incidental out-of-match wear.
-Sir Francis Bacon
-Albert Einstein
Unread 14-01-2007, 15:02
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I'll second Andrew Blair's comments. I have never seen a piece of lexan actually fail outright. I've seen it get bent or deformed slightly. So unless you need structural rigidity out of it keep it very thin and you'll do fine.
One suggestion is to arc it over the part of your robot that you want to protect. The shape of the lexan will help it deflect and absorb blows. The bowed shape also makes it stiffer than if it was layed flat over a hole.
Team Website
Unread 14-01-2007, 15:06
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Last year our team built allmost all of the robot out of 1/4 in pollycarbonate expect for the frame. It was verry heavy and you do not need it that thick if you structure it correctly. This year were building every thing out of 1/8 in pollycarbonate. So I would recenmend 1/8 in.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 14-01-2007, 15:27
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
if you have a full frame for it go 1/16, especially if it`s a large area you have to cover. it`s cheaper, lighter, and usually just as effective. The only time our team uses 1/8 is to cover our electrical panel, or where there`s one side with no framing.
we`ve covered huge areas and just attached it with velcro, and even some of the toughest blows have not gone through. (I don`t know if velcro is still legal... anyone?)
only thing to think of is maybe bringing a spare just in case.
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Lexan is a great material but it's heavy, really heavy. A few alternatives I've seen several teams use over the years is a Green House like, Corrugated Polycarbonate Material, lightweight with a bit more stiffness. Off the top of my head 173 and 1126 are 2 successful teams that have used the material extensively.
Unread 14-01-2007, 19:47
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
velcro is legal...
Unread 14-01-2007, 21:48
DonRotolo's Avatar
Back to humble
FRC #0832
1/16" is plenty for scrape protection, especially if supported.
For impact protection, thicker is better - BUT aren't you guys thinking about bumpers for this year? If so, let THEM be your side protection.
Although they must be made from 3/4" plywood, you don't want CDX (the plain builder's plywood) --- use hardwood plywood (not the luan stuff Home Depot sells, but Maple, Birch or Oak, also known as marine plywood or aviation plywood) as it is really strong - I mean realllly strong. And, there's no weight*!!
Don
*well, not included with the robot, and enough to surround your entire bot won't exceed 15 pounds either...
Unread 14-01-2007, 23:01
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
At the Ruckus, GRR put 1/4" polycarb on the sides of the robots. We could kick, punch, launch tools, etc. at them all day long and nothing would happen. Remember, you'll need to make sure the lexan/polycarb is securely fastened in many different points if you want it to work properly and to its potential.
Unread 15-01-2007, 13:55
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
If you use 1/2" and up your robot will be bullet proof for small arms fire....
Frame tubing wall thickness sanddrag Technical Discussion 5 03-06-2005 11:04
Image Discuss: 121's Side Panel Decal CD47-Bot Extra Discussion 6 08-02-2003 15:23
Fiberglass Thickness archiver 2000 1 23-06-2002 22:53
Thickness of aluminium bars Randy_Ai Technical Discussion 1 04-02-2002 20:09
gear thickness zarb Technical Discussion 10 26-01-2002 22:07
