Go to Post Oh no, do I see a new reality TV show coming? "Dancing with the FIRST Stars"??? :ahh: - KathieK [more]
Unread 11-01-2007, 22:14
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
sprockets
If i use the andymark kit wheels and try to make a six wheel drive, is there a way to mount two sprockets on the center tire? Can i simply buy the appropriate long bolts from home depot and some small washers or do i need to use hardware titled for the wheels?
Unread 11-01-2007, 22:18
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: sprockets
I dont see why you cant just use long bolts, thats what we would do.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 11-01-2007, 22:19
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: sprockets
We are doing the same thing with a 4WD chassis. Just get a longer bolt and run it through the wheel, and through both sprockets. Then bolt it down.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 11-01-2007, 22:28
Adama's Avatar
Re: sprockets
cool
thanks
Unread 11-01-2007, 22:42
Adama's Avatar
Re: sprockets
what kind of bolts might those be? i know it says somewhere but i am going dumb now that its 11pm
Unread 12-01-2007, 11:17
Mechanical/Driver
Re: sprockets
I believe they are .165" holes. Standard 10-32 bolts/nuts from lowes will fit.
Unread 12-01-2007, 22:25
Stuart's Avatar
#include coffee.h
Re: sprockets
8-32 not 10-32. took us an hour at home depot to find 2" 8-32(its a bad home depot)
Unread 13-01-2007, 16:05
Mechanical/Driver
Re: sprockets
Are you sure? On the AndyMark site it says the holes are drilled for 10-32.
Originally Posted by http://www.andymark.biz
Mounting Holes
6 holes (0.165") for #10-32 screw on a 1.875" dia bolt circle. Threads will need to be tapped into these holes.
Unread 13-01-2007, 16:11
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: sprockets
10-32 if you were going to tap them, 8-32 if you want to use them as through-holes.
Unread 13-01-2007, 22:49
Adama's Avatar
Re: sprockets
thanks again everyone
Unread 14-01-2007, 12:01
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: sprockets
whats even stronger is to drill out the holes and use 10-32 or M4x0.75 through bolts
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 14-01-2007, 13:39
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: sprockets
last year we used long bolts and simple home made spacers and it worked great. Just be sure to use loctite or they will work loose.
Unread 14-01-2007, 14:05
Carmine Rizzo Carmine Rizzo is offline
FRC #0075 (RoboRaiders)
Carmine Rizzo is just really niceCarmine Rizzo is just really niceCarmine Rizzo is just really niceCarmine Rizzo is just really nice
Re: sprockets
This is possible and we have done this in the past. If you are going to do this you have to consider several items.
Any slop in the Bolts and holes will give you a potential failure point from the sheer forces. This will be exacerbated by the slop in the housing.
Things to consider
Oversize the holes on the wheels to .1875-.189.
Add Spacers (Aluminum will work) to the sprockets try not to use a hub on the sprocket for weight.
C’Bore the sprockets for the spacers
Use Socket Head Cap (Ask a local machine shop or Hardware store, not Home Depot, Allen or Holo Krome) screws, as they are harder and will provide the strength.
Use ny-loc nuts for later removal
Do a PM (Preventive Maintenance) between matches and have spare screws
Good Luck from Team #75
Team #75 Mentor
sprockets carbuff Kit & Additional Hardware 8 12-01-2007 08:30
Sprockets laney836 Chit-Chat 3 02-11-2005 19:46
Sprockets VinceT Kit & Additional Hardware 4 18-01-2004 23:07
sprockets BBFIRSTCHICK Technical Discussion 21 09-02-2003 01:01
sprockets Greg Needel Technical Discussion 0 23-04-2002 12:30
