Go to Post Lengthy posts are not discarded ones. Information comes in all sizes - Garii [more]
Unread 14-01-2007, 14:42
foote stepped in
AKA: E. Foote
FRC #0868
Re: What row will you score on or will you score at all?
we're actually going to score every tube. even the ones that aren't ours. We won't be using will power; rather we will be using the magic smoke out of our camera, victors, and other various electronics. Its pretty potent stuff.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 14-01-2007, 15:46
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Be careful with that magic smoke, remember a little goes a long way.
KK4KQO
http://voltair.us
Unread 14-01-2007, 17:08
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Our team is planning on building an arm that can score on all three heights and pick up the rings from the round and all three spider feet levels. Unfortunately I don’t think our team has the expertise to use magic smoke safely so our arm will need to be built with old fashion engendering and machining.
2004 - 2012: Team 1100
2013 - ????: Team 131
Unread 14-01-2007, 21:35
NoSkaOnTheRadio's Avatar
NoSkaOnTheRadio NoSkaOnTheRadio is offline
Team 1757 Alumnus
AKA: James Carney
FRC #1757 (The Big Green)
NoSkaOnTheRadio has a spectacular aura aboutNoSkaOnTheRadio has a spectacular aura about
Send a message via AIM to NoSkaOnTheRadio
team 1757 is going for trilateral scoring ability!
...or maybe we'll just try to score on all three levels. in any case, we said we'd try to score in the low goals last year, and i'm pretty sure we scored one poof ball all competition with our robot (go rookies); i don't know how much i can trust us . all the other balls we scored were a direct result of my cannon arm and lucky bounces . hopefully our sophomore season won't be as scary as our rookie one.
and i want to holla at the t-hawks (!), who i'm sure we'll be seeing again in boston this year
Unread 14-01-2007, 22:18
Scion13's Avatar
Scion13 Scion13 is offline
AKA: Steve
FRC #1727 (REX)
Scion13 is on a distinguished road
Last year we decided to go for both the center goal and the ramp and it turned out pretty well. This year we're going for everything again.
REX 1727
www.dulaneyrobotics.com
2007 Chesapeake Chairman's Award
2007 Chesapeake Safety Award
2007 New Jersey Entrepreneur Award
2006 Pittsburgh Rookie All-Star Award
2006 Pittsburgh Website Award
2006 Annapolis Best Seeded Rookie Award
Go BAA!
(Baltimore Area Alliance)
Unread 14-01-2007, 22:33
easponge's Avatar
easponge easponge is offline
You're off the team!
AKA: Betsy Soukup
FRC #0694 (StuyPulse)
easponge is an unknown quantity at this point
I think scoring in the middle row would probably be the best position strategically, since you can continue making a vertical row either from the upper or lower "spider leg." Other than that, I'd guess the bottom row.
Unread 15-01-2007, 15:56
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Our team is working on an arm that would theoretically be able to get up to the top row, though it's more likely we'll just stick with the bottom two. The primary function of our robot will be a Defender/Platform for the end of the match so the arm is a secondary priority. If we have enough weight we'll go for all 3.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 15-01-2007, 17:35
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
It is key in this game to be flexible with your scoring options and tube retrieval options. I think it is an important strategy to work with your alliance partners on this one, such as one team taking a specific part of the rack. Although this may create another defensive strategy to notice scoring patterns and then block a team from their section, that's a completely different story...
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 28-01-2007, 18:13
imax48236's Avatar
imax48236 imax48236 is offline
El Presidente
AKA: The Elf
FRC #1701 (Robocubs)
imax48236 will become famous soon enough
Send a message via AIM to imax48236
Our team has an extendable lift which travels 10 feet in the air. We will score on all three levels.
2007 Events:
Great Lakes Regional
Detroit Regional
<THIS SPACE FOR RENT, $3000 donation to Team 1701>
Unread 28-01-2007, 18:20
foote stepped in
AKA: E. Foote
FRC #0868
we've got a design in mind that will effectively score on all three levels. The only problem now is implementing it
(btw, we haven't figured out how to completely tap into the powers of magic smoke, so we've started actually engineering )
Unread 29-01-2007, 15:49
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
arm is being designed to score in all three. and we are going to magically levitate and lift 2 bots for 90 extra points
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 29-01-2007, 16:06
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Let the scouting begin!!
Top row!!
Unread 29-01-2007, 17:10
RoboDriver1718's Avatar
RoboDriver1718 RoboDriver1718 is offline
AKA: Cole W
FRC #1718 (The Fighting Pi)
Team Role: Driver
RoboDriver1718 is on a distinguished road
Send a message via AIM to RoboDriver1718
Lightbulb Re: What row will you score on or will you score at all?
Our team will figure that out when we get the arm finished but as it stands right now our goal is all three.
Unread 29-01-2007, 17:55
Sean Marks's Avatar
Sean Marks Sean Marks is offline
AutoCAD User
AKA: Sean Marks
FRC #2016 (Mu Mu Psi)
Team Role: Student
Sean Marks is a jewel in the roughSean Marks is a jewel in the roughSean Marks is a jewel in the rough
Send a message via AIM to Sean Marks
Talking Re: What row will you score on or will you score at all?
were shooting for the middle and lower rows, using the arm we desingned we might be able to go higher but were gonna try and keep it simple.
2008-NJ Semi-Finalist (Thanks 694 & 1279) / Chesapeake Winners (Thanks 1418 & 11) / Newton Finalists (Thanks 1574 & 141)
2007-NJ Rookie All-Star / Monty Madness Champs
What do you think will happen....? slickguy2007 General Forum 7 29-01-2007 18:39
What environment will you use? Astronouth7303 Programming 14 09-01-2007 14:58
what do you think high score will be nuggetsyl General Forum 13 03-04-2006 14:03
what kind of steering do will you have? Alex Cormier Technical Discussion 2 30-01-2004 20:38
SENIORS!! what college will you be attending? Renzorocks Chit-Chat 40 05-06-2002 16:54
