Go to Post i just want to say how awesome the high volume tank is. The high volume tank is 7/4 as awesome as the previous tanks. - Tytus Gerrish [more]
Unread 11-01-2007, 14:32
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
can we use ultrasonic sensors?
I'm thinking of a design that would use an ultrasonic range finder/ proximity sensor to determine where the spider leg is during autonomus scoring...
But I have no idea if they are legal this year? I think 71 & 1 used the vex model last year to sense weather there was a ball at a sertain part in their robot last year...
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 11-01-2007, 14:36
Back after 4 years off
FRC #5279
Re: can we use ultrasonic sensors?
They are legal, provided they fit all criteria in the flow chart.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 11-01-2007, 14:56
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
As long as they follow the flow chart, they'd be fine.
On a side note, you may want to look at possibly using IR range sensors as an alternative to the ultrasonics if they have characterstics you don't like. That looks like the route we're going, since we don't like the wide field of view of the ultrasonics.
Unread 11-01-2007, 15:02
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Yes, the VEX units are legal in FRC. They are excellent for detecting objects infront of your robot. You just need to change the connectors to female for the FRC controler. That or make a female-female cables so you don't have to modify the sensor. They are excellent for detecting metal 10" disks infront of your arm. There are drivers avalible for it in easyC and MPLAB.
Unread 11-01-2007, 15:06
GMKlenklen's Avatar
The "Masonater"
What about third party sensors?
also, is it possible to detect the edges of the spider feet with this type of sensor?
or is it just goigng to read a distance off to the controller?
Thank you,
-of the MASMabots-
Unread 11-01-2007, 15:22
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
We also are considering using sonic range finders.
At the top of our list is this one:
http://www.maxbotix.com/
You may also wish to read this thread discusising some testing of it.
http://www.chiefdelphi.com/forums/sh...ad.php?t=46912
I've done mostly the same testing as the thread with similiar results.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 11-01-2007, 15:58
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Ultrasonic range finder/ proximity sensors may be use as long as they meet all other rule. Check the flow chart.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 11-01-2007, 16:25
Kingofl337's Avatar
AKA: Adam
The MaxSonar-EZ1 looks like a really nice sensor. It has an option to return analog voltages so it should be extreamly easy to use. Plus it doesn't eat precious interrupt ports. Looks like I might have to pick up a new toy to play with.
Unread 13-01-2007, 22:18
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
I too would like a Maxbotix sensor..(drool)...but I'm a little leery about buying from a distributor I have never heard of.
Does anyone here know of a reputable distributor of this type of sensor, or an IR distance sensor? I am interested in getting one, but I don't know where to look. Parallax has one, but its range doesn't seem high enough for the application I have in mind.
Thanks,
JBot
Aren't signatures a bit outdated?
Unread 13-01-2007, 22:57
FreakyAntelope's Avatar
FreakyAntelope FreakyAntelope is offline
Unregistered User
AKA: Toby Waite
#0246 (Overclocked)
Team Role: Electrical
FreakyAntelope will become famous soon enough
Send a message via AIM to FreakyAntelope
If it's any comfort, team 246 ordered a Maxbotix sonar sensor, and had no problems with the vendor. It's a very nifty sensor. It's pretty accurate, and very easy to set up.
Toby
Unread 13-01-2007, 23:02
Netherlander Netherlander is offline
FRC #1006 (Fast Eddie Robotics)
Netherlander is an unknown quantity at this point
This sensor looks good but I do have some qualms about using the ultrasonic sensor. First of all there are potentially way to many things that the signal could bounce off of and secondly if any other robot is using ultrasonic sensors they have a good chance of interfering with each other.
Unread 14-01-2007, 00:46
Bharat Nain's Avatar
Those of you who purchased one, care to share any test results(preferably on the rack)?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 14-01-2007, 14:59
Dancing_Chuck's Avatar
Dancing_Chuck Dancing_Chuck is offline
AKA: Chuckles
FRC #1111 (Powerhawks)
Dancing_Chuck will become famous soon enough
Send a message via AIM to Dancing_Chuck
So, lemme get this straight. We can use up to, but not including 900 mega hertz (or however you spell that, you get the drift). Does this include any camera? Can we use military-style cameras? Or is that out of the question?
You can dance if you want to, you can leave your friends behind
'Cuz if they don't dance when you want to dance, then they're no friends of mine!
http://video.google.com/videoplay?do...60835799858748
Unread 14-01-2007, 15:03
Spark Hawk's Avatar
Spark Hawk Spark Hawk is offline
Alumnus
AKA: Patrick
Spark Hawk is an unknown quantity at this point
If Chuck is right, that's insane
Unread 14-01-2007, 15:17
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Yeah they should be legal, a few teams that saw last year bought some Vex Ultrasonic Sensors and used them without problems. The Vex sensors are great and if you don't use them on your FRC robot, you can use them on your Vex robot!
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 22-05-2006 12:08
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Is there a restriction to what sensors we can use? Robot Dude 0101 Kit & Additional Hardware 28 11-01-2005 22:43
Current sensors use?? zainali Motors 1 09-02-2004 19:04
