Go to Post Once you go hex you'll never go back. - sdcantrell56 [more]
Unread 14-01-2007, 15:49
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Got Gyro?
Originally Posted by PhilBot View Post
Is there an "approved" gyro board available this year?
Anyone have a part number?
Here you go:
http://www.sparkfun.com/commerce/pro...roducts_id=395
This is the Gyro we use.
It's pricey but it works great.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 15-01-2007, 00:34
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Got Gyro?
Thanks everyone. The email will go out tomorrow....
So much to read, so little time
Phil
Phil Malone
http://www.GEARSinc.org
Unread 15-01-2007, 09:38
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Got Gyro?
Originally Posted by Mike Copioli View Post
Here you go:
I'll second this. The turn rate of the kit gyro is too easy to hit. We used the ADXRS300 last year as well, although we wired up the eval board. The SparkFun one looks a bit easier to wire up.
We're using a gyro this year as well, it was really nice when the students rigged up a PID loop to keep the robot driving perfectly straight.
Unread 21-01-2007, 22:13
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
michael714 is on a distinguished road
Re: Got Gyro?
Hey Folks,
I submitted a request for the gyro and the accelerometer on 1/6 and still haven't received anything. Has anyone received theirs?
Unread 21-01-2007, 22:31
Re: Got Gyro?
Originally Posted by michael714 View Post
Hey Folks,
No. We have not recieved ours either.
Mike Copioli
Unread 22-01-2007, 07:39
kaszeta's Avatar
Re: Got Gyro?
Hey Folks,
Team 95 received ours late last week.
Unread 22-01-2007, 09:50
Molly Stieber Molly Stieber is offline
FRC #0269 (Cooney Tech Robotics)
Team Role: Electrical
Molly Stieber is an unknown quantity at this point
Re: Got Gyro?
We haven't received ours yet either, and i ordered it the week after the kickoff.
Unread 22-01-2007, 11:35
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
Re: Got Gyro?
That sounds interesting. I wouldn't mind learning more about this technique.
/Jason
Unread 22-01-2007, 11:47
kaszeta's Avatar
Re: Got Gyro?
Our robot is basically a tank drive (left side and right side wheels centered on the robot), driven by a single joystick:
1. p1_y determines the speed of the robot. Set both L and R motors to this speed.
2. p1_x adjusts the desired heading of the robot.
3. Every time through the loop, you look at your current heading, and the
desired heading, and use the error between the two in a PID control loop
to set the amount you're adding to one side and subtracting from the other
to turn the robot to correct the heading.
This allows us to correct for motor biases and different traction between left and right and drive in a straight heading.
We've also used this same approach with a omnidirectional drive system, although we've never gone to competition with it.
Unread 22-01-2007, 16:44
Kyveck Kyveck is offline
FRC #1014 (Dublin Robotics)
Kyveck is an unknown quantity at this point
Re: Got Gyro?
On 1014 we used a gyro drive very successfully last year. On the night before ship the mechanical teams accidentally estroyed the last of our encoders, so we had to scrap our encoder-PID drive. Since our drivetrain was fairly difficult to control as it was, we decided to work out something with our only remaining working sensor, the gyro.
Our algorithm was essentially like the descirption above. It took us about 45 minutes to code and tune. After it was done, our robot could easily be driven by almost anyone who wanted too. Even with the PID drive on the encoders, only a few people on the team were coordinated enough to not hit things. When the coding was done I was able to drive it on my own and chase the person who killed our last encoder around the room shooting balls at him. (That was fun.)
We got our camera working Saturday so that we can chase a green light on a cart around the school with a PI loop, and now are reimplementing the same gyro algorithm as last year to try to approach the cart without waffling side to side as much. Since the robot doesn't have encoders installed yet, the only feedback currently is from the camera.
I don't know how much experience you have programming for FRC, but if you need some help, I can talk to my programming team and get some code samples.
Kyle W
Engineering Director, Team 1014
Unread 24-01-2007, 12:41
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: Got Gyro?
Kyle W
Very interesting. Did you start with Kevin's code? We're going to be trying this this year- assuming we ever get the Gyro offering.
Unread 22-01-2007, 09:47
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: Got Gyro?
Here you go:
Thanks Mike and kaszeta, I usually buy the adxrs300eb right from analog devices, but they are out of stock 'till 6/07 and digikey is out until 4/07. =/ SparkFun didn't even come up on a google search. I was looking at piezo sensor yaw rate controllers for r/c helicopters, but we 'd have to hack one and I couldn't find the sensitivity (300deg/sec) we need anyway.
The SparkFun website says that their stock is down to under 20, so order one quick
Thanks
EricS
Don't PANIC!
S. P. A. M.
Unread 22-01-2007, 10:30
kaszeta's Avatar
Re: Got Gyro?
I'm convinced that somewhere, the various inventory control guys at Digi-key, Newark, and Sparkfun all wonder why every January there is a run on ADXRS300 gyros, Grayhill 63R128 encoders, and the other various components many 'bots use that I can easily buy the rest of the year, but suddenly become out of stock during the build season.
Unread 22-01-2007, 11:00
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Got Gyro?
Hah, yeah, yet another reason we tend to purchase hard-to-find items during the off-season. We see FIRST like Christmas, do all your shopping for things you know you need or that you're low in stock of in order to beat the Christmas rush.
Ho Ho Ho.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Got Weight? Dominicano0519 General Forum 56 27-02-2006 22:06
Got NERVE? KathieK General Forum 0 13-02-2006 18:11
I got GAME! Goober!!! Games/Trivia 3 07-02-2005 21:43
Got Mak? Quentinfool General Forum 5 19-05-2003 17:54
Got Robot? Chubtoad General Forum 19 08-05-2002 22:21
