Go to Post To me, being in FIRST is the biggest learning experience anyone can have. I want to give that experience to everyone I can, be it now or thirty years down the line. - BandChick [more]
Unread 14-01-2007, 18:34
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Re: Attempting to Cut BaneBot 56mm Shaft
Get a pneumatic cutoff grinder. It will make quick work of the shaft. You can also use a regular 4" electric grinder with a cutoff wheel in it. Just keep a eye on the shaft temperature.
BaneBot Transmission Encoder Daru Motors 9 27-01-2007 23:17
Banebot 2 motor adapter Ben Piecuch Motors 5 17-01-2007 16:06
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
