Go to Post Some things in life are far more important than Robotics. - IMDWalrus [more]
Unread 14-01-2007, 18:41
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Re: Attempting to Cut BaneBot 56mm Shaft
Originally Posted by Richard View Post
There may be a safe, reversible method of disassembling the unit so that you can securely clamp the shaft and final spider assembly for cutting, but since I haven't attempted that I can't offer advice -- maybe Dr. Joe or (again) someone from BaneBots can, or maybe you'll need to experiment.
We opened our 42mm up today. Once you've got the four screws out, everything's pretty easy to take apart.
That was the little gearbox, not the 56mm. I can't vouch for the assembly of the 56, but there are good odds that it's the same, so if you just go slow and make sure you don't lose or break anything, you should be fine.
Before you close it up, make sure you clean and lube it up if you got any dirt in the gears or lost a lot of the grease.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
BaneBot Transmission Encoder Daru Motors 9 27-01-2007 23:17
Banebot 2 motor adapter Ben Piecuch Motors 5 17-01-2007 16:06
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
