Go to Post And trust me, the very last thing you want to see is me with time on my hands and access to power tools. - dlavery [more]
Unread 14-01-2007, 15:19
Dancing_Chuck's Avatar
Dancing_Chuck Dancing_Chuck is offline
AKA: Chuckles
FRC #1111 (Powerhawks)
Team Role: Electrical
Dancing_Chuck will become famous soon enough
Send a message via AIM to Dancing_Chuck
Re: can we use ultrasonic sensors?
Yeah, I'm gonna get some military sensors and our robot is gonna home in on the spider like.... a bomb. Hehe!
You can dance if you want to, you can leave your friends behind
'Cuz if they don't dance when you want to dance, then they're no friends of mine!
http://video.google.com/videoplay?do...60835799858748
Unread 14-01-2007, 19:22
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
The Maxbotix sonar sensors are available from Sparkfun, who is a pretty large hobby robotics distributor, so I'd say there at least decent if Sparkfun is willing to carry them.
As for IR Range sensors, you can get ones made by Sharp (easily the biggest maker of them) from either Acroname or Digikey. Just search for any of these companies and you'll find their websites.
Unread 14-01-2007, 22:08
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by JBotAlan View Post
I too would like a Maxbotix sensor..(drool)...but I'm a little leery about buying from a distributor I have never heard of.
See http://www.chiefdelphi.com/forums/sh...ad.php?t=46912
Originally Posted by Netherlander View Post
This sensor looks good but I do have some qualms about using the ultrasonic sensor. First of all there are potentially way to many things that the signal could bounce off of and secondly if any other robot is using ultrasonic sensors they have a good chance of interfering with each other.
How very true, you have hit upon their greatest weaknesses.
Originally Posted by Dancing_Chuck View Post
So, lemme get this straight. We can use up to, but not including 900 mega hertz (or however you spell that, you get the drift). Does this include any camera? Can we use military-style cameras? Or is that out of the question?
Not sure what you refer to, but ultrasonic (sonar) sensors (the subject of this thread) operate in the high audio range, far far below the Radio Frequencies you mention. Use the flowchart to determine what is legal.
Don
Unread 14-01-2007, 22:56
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Don
um ultrasonic is still sound, which is pressure waves, radio is electro-magnetic waves.. Sound waves won't ever interfere with radio waves, no matter if the "frequencies" are the same.
Unread 15-01-2007, 14:13
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Beware of ultrasonic interaction with pneumatics
If you are going to use ultrasonics, be careful, for a number of reasons.
1) Try to keep the sonic environment relatively "closed"/"close". By that, I mean just as with active IR rangers, the more localized the sensor's effect, the better. Example: Sensing the spider's endplate with something on your gripper is OK. Blanketing the entire field with a slew of ultrasonic sensors pointing in all directions looking for the rack is questionable. The latter is prone to interference from reflections, and background noise. It could also potentially interact with other robot's sensors. This is not only Ungratious, it could cause a judge to rule your sensor system illegal.
2) Be aware that pneumatic venting "whistles" loudly in the ultrasonic. If your sensor is anywhere near a venting pneumatic's air output (yours, a partner's, OR an opponent's) , it can potentially be swamped out by the "dog whistle effect". (Yet another reason to keep your sensing "local".) Verify your sensor(s) aren't affected by your pneumatics venting.
If they are affected, there are some simple things you can do about your OWN interference:
A) Point your valve's vents away from your ultrasonic system. That may be sufficient to prevent interference.
B) If (A) isn't sufficient, combine all of your pneumatic vent outputs together with T-connectors and add a foam "muffler"/"silencer" to the resulting output vent tube. They're COTS - search for "pneumatics muffler", "air exhaust silencer" etc...
C) Run a short "exhaust" vent tube to/toward the far end of your robot and point the pneumatic exhaust opening away from your sensor system.
D) Do both B&C (locate a pnaumatics muffler far from your sensors).
<edit>
3) The PIAB vacuum generators MAY swamp out ultrasonics for this contest! I haven't tested them, but venturi vacuum generators must vent constantly to work at all. Ultrasonic systems on your robot MAY then be hearing nothing but serious dog whistles from a significant number of bots on the field in every round.
Anyone happen to have the equipment to check to see if they whistle anywhere near 40 KHz? (That's roughly where most ultrasonic systems run.)
</edit>
I hope this helps!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 15-01-2007, 14:34
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Does anyone here know of a reputable distributor of this type of sensor, or an IR distance sensor? I am interested in getting one, but I don't know where to look. Parallax has one, but its range doesn't seem high enough for the application I have in mind.
Thanks,
JBot
I've ordered all sorts of IR stuff and other sensors from Sparkfun.com with no problems.
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 22-05-2006 12:08
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Is there a restriction to what sensors we can use? Robot Dude 0101 Kit & Additional Hardware 28 11-01-2005 22:43
Current sensors use?? zainali Motors 1 09-02-2004 19:04
