Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Unread 14-01-2007, 21:24
NoSkaOnTheRadio's Avatar
NoSkaOnTheRadio NoSkaOnTheRadio is offline
Team 1757 Alumnus
AKA: James Carney
FRC #1757 (The Big Green)
NoSkaOnTheRadio has a spectacular aura aboutNoSkaOnTheRadio has a spectacular aura about
Send a message via AIM to NoSkaOnTheRadio
Re: Robot Arm Extension
i think someone should draw a picture of this .
Unread 14-01-2007, 21:39
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Done:
I love my tablet
KK4KQO
http://voltair.us
Unread 14-01-2007, 22:10
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
that thar's some gud drawin skil!
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
Unread 15-01-2007, 08:41
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Originally Posted by GDC
The intent of Rule <R12> is that the robot must be able to fit within a 72" x 72" virtual box at all times. The orientation of the robot within the box is inconsequential
inconsequent: lacking worth or importance.
By this defination the orientation of the robot does not have an importance or worth. Therefore it doesn't matter which way the robot faces it would still be out of the box. Just think about it, if they meant it. they would have to give everyone a direction in which this virtual box faces.
Orginally posted by shamuwong
Actually, the rule book specifically tells teams not to "lawyer" the rules and such. By that, they mean stick to the spirit of the competition and don't look for loopholes to get the advantage through devious game play.
I think innovation refers not to creativity in interpreting the rules, but rather, the game.
Don't read too much into it. 72 inches is 72 inches regardless of what way you face your robot.
Unread 15-01-2007, 09:24
bobotics319 bobotics319 is offline
AKA: Andrew Levasseur
FRC #0319 (Bobotics)
Team Role: Communications
bobotics319 is an unknown quantity at this point
My interpretation of the rule is that as long as you can take your fully extended robot and put it in a 72x72 inch box (regardless of robot orientation), you're legal.
I think FIRST needs to make some clarifications.
Unread 15-01-2007, 10:09
FRC #1360
I agree FIRST needs to clearify this, because some people might try this diagonal approach, personally, I would rather be safe than sorry
Unread 15-01-2007, 10:19
in between teams
AKA: Luke Van Oort
They did. Here.
Team 1219: 2009 - Mentor
Unread 15-01-2007, 10:27
FRC #1360
this quote has been posted many times. Yet there is still room for inturptations more clearification is needed
Unread 15-01-2007, 10:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's about as clear as can be....you have a 6 foot square box to fit your robot into. You can have it aligned diagonally, straight, or whatever way you want. That's what "the orientation of the robot within the box is inconsequential" means.
Unread 15-01-2007, 10:47
FRC #1360
Fair enough.. I'm just trying to be on the safe side. I don't want be Dq'd for something as small as that lol.
Arm Extension Question predator_hunter Rules/Strategy 6 11-01-2007 21:10
ARM GEARING ON ROBOT kshag Technical Discussion 11 27-02-2005 21:02
**IMPORTANT FIRST EMAIL**/Robot Ship Extension News with Season Information and Upda miketwalker FIRST E-Mail Blast Archive 0 13-02-2004 18:02
Robot Controller arm David Kelly Technical Discussion 0 28-06-2001 16:37
