Go to Post "When you lose you don't say anything. When you win you say even less." - Clinton Bolinger [more]
Unread 12-01-2007, 23:58
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Question Debouncing
One simple, quick question:
Do the joysticks (and other arbitrary toggle switches on the OI) need to be debounced in software, eg. checking to make sure that a joystick button value stays constant for a certain number of new data packets before accepting it?
Thanks in advance,
Robinson
Unread 13-01-2007, 00:35
Electrical Engineer
Rookie Year: 1995
Re: Debouncing
Robinson,
Most people do not because a switch bounce is usually 3 or more orders of magnitude faster than the OI update rate. Only once in 13 years has my team needed a debounce routine on an OI input.
However, your mileage may vary...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 13-01-2007, 08:57
AKA: Robinson Levin
Re: Debouncing
Thanks.
Unread 14-01-2007, 19:38
P1h3r1e3d13's Avatar
P1h3r1e3d13 P1h3r1e3d13 is offline
Unregistered User
FRC #0295
P1h3r1e3d13 is an unknown quantity at this point
Re: Debouncing
I second.
Last year, on the advice of an electrical engineer mentor, I wrote a fairly long
debounce subroutine that I called for every switch input, totally forgetting how slow the processor is.
Long story short, it caused a lot of problems and wasted a lot of my time (a good half-week, and I was the only programmer). I realized later how silly that was, because we never ever had any bounce problems without it.
Unread 14-01-2007, 21:51
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Debouncing
I agree, we did not debounce our custom switches last year and saw no issues.
Don
Unread 15-01-2007, 00:11
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Debouncing
Our team used a debouncer last year, because we've had issues with buttons in the past (notably a joystick trigger in 2005, where sometimes it would see itself flipping on/off very quickly and try to actuate a pneumatic cylinder equally as fast).
I plan on using it again this year, and for the magnetic reed switches on cylinders in addition to buttons.
However, whether or not they are necessary is entirely dependent on how you control things, and whether or not your team is having issues with buttons. It's not difficult to do, but if there's no problem, those few hours on that are better spent elsewhere.
Unread 15-01-2007, 00:39
AKA: Robinson Levin
Re: Debouncing
Thanks for the advice everybody. I guess while I have no robot to play with I will go ahead and write debouncing code to use with any toggle switches we may have on the OI. I don't see a disadvantage to the 100ms spent debouncing, as that is still an order of magnitude faster than the robot would operate anyway.
Thanks again,
Robinson
