Go to Post Like a moth to a flame, true FIRSTers are attracted by the Victor instead of the Banner. - Rich Wong [more]
Unread 13-01-2007, 15:37
Inverted Inverted is offline
AKA: Eric P.
FRC #1228 (Robo Tribe)
Inverted is an unknown quantity at this point
Send a message via AIM to Inverted
Angry Please help. I've had it with this camera
Ugh. Fir the past 3 years I've been trying to get the camera to track the light, and every year I just can't get it. This year I managed to get the camera to recognize the color and track it, but I can't get the servos to move it. I download the easyC camera test program and downloaded to the robot, but it doesn't seem to do anything. I set the variables for the left and right drive motors equal to the respective PWM ports, but I can't seem to find where the pan and tilt servo pwm ports are defined. When I download the program to the bot, it doesn't do anything. In autonomous, neither the servos nor the wheels move, and in regular mode the joystick has no control over the wheels; the bot is just dead.
I'm at a loss right now. I don't know what I'm supposed to do with the program or how it's supposed to work. Furthermore, I have no desire to do programming this year, but unfortunately I'm the only person on the team who knows how to and I have to train younger members how to.
Unread 13-01-2007, 17:21
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Please help. I've had it with this camera
for easyc code, servo ports 10 and 11. for kevins code, 1 and 2
I managed to hack around with the given code, and got it to track pretty easily. Don't expect everything to be given to you, and read some more about C. It's a fairly complex language, but extremely powerful
Unread 13-01-2007, 18:08
AdmiralAllen's Avatar
AdmiralAllen AdmiralAllen is offline
Master of Computers and Robots
AKA: Allen Worcester
FRC #1662 (Raptor Force Engineering)
AdmiralAllen will become famous soon enough
I'm having a very similar problem....
the camera follows the light.... but how do i get the whole robot to go twoards the light, and still be able to change direction or stop when it gets close?
Unread 13-01-2007, 18:55
rodgadashruba rodgadashruba is offline
FRC #0611
rodgadashruba is an unknown quantity at this point
after messing with the camera some, the camera will return the values for the servos... now that u have the values, you need to determine the angles and have the robot to move according to those values, I do not have the code to look at now, but when i get a chance I will post some code snippits that might help
Unread 13-01-2007, 19:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
It's probably the easiest to drive with the centroid value. So, in easyC you can use the two/four wheel wheel drive function and in MPLAB you can using the mixing value.
If you do:
Set you gain low and work your way up. Your robot should drive to
the target with this. Your best is to only have it track only one thing at a time. Center - Drive - Center - Drive....
Error_Y = (Centriod_Y_Target - Centriod_Y_Current);
Rotation = (Error_Y * Gain_Y);
Error_X = (Centriod_X_Target - Centriod_X_Current);
Speed = (Error_X * Gain_X);
QUOTE=AdmiralAllen;555954]I'm having a very similar problem....
the camera follows the light.... but how do i get the whole robot to go twoards the light, and still be able to change direction or stop when it gets close?[/quote]
Unread 14-01-2007, 22:30
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Do you have the backup battery installed? The blue one. The servos are not powered unless the backup battery is installed. The 12V supply to the RC does not power the servos.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 14-01-2007, 22:35
bobmonkey836's Avatar
bobmonkey836 bobmonkey836 is offline
BobMonkey07
AKA: Jeff Powers
FRC #0836 (Robobees)
bobmonkey836 is on a distinguished road
so everyone wants their robot to go towards the light? well, at least it's green, not white.
Solution to life's problems: "CTRL", "ALT", "DELETE".
"CTRL"+"Z" Saved my life.
Approximately Normal
2007 Annapolis Regional at USNA!!
Management is doing things right; leadership is doing the right things.
- Peter Drucker
Premiere won't recognize camera - please help sanddrag IT / Communications 9 04-01-2007 20:17
please help me to plag in the camera CompMaster Programming 1 16-02-2006 11:24
HELP! I've gotta come up with a radio show! Billfred Chit-Chat 13 01-09-2004 19:45
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
Ahhhh! I've had it with 3dstudio max! AnnyRob 3D Animation and Competition 6 29-01-2002 11:23
