Go to Post I hope FIRST hurries up and releases the regional schedule soon. I have a vacation schedule to plan. - Koko Ed [more]
Unread 11-01-2007, 17:11
Uchia_Itachi's Avatar
Uchia_Itachi Uchia_Itachi is offline
FRC #1561
Uchia_Itachi is an unknown quantity at this point
Fisher Price Motors
Hello everybody. Im a verteran member of my team 1561, the Roboducks. Although I have spent a lot of time on our previous robots, we never tried to use the fisher price motor. This hear we are thinking about using the fisher price motor, but do not know how to go about doing that. It would really help if anyone could tell us how you have used it in previous competitions and how you would go about hooking it up. Thanks in advance.
Unread 11-01-2007, 17:22
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Fisher Price Motors
The Fisher Price motors are among the most powerful motors in the kit.
They are wonderful little power packs.
You have to be careful not to load the motor so that it runs too slow or the motor will fry but, that is pretty easily done. For the most part it just means picking a high enough gear ratio and not running the motors to stall if you are driving an arm or something against a stop.
I also am a big fan of using the FP motor but not the FP gearboxes. I think the Nothing But Dewalt Whitepaper is a good method. But unless you need shifting, I have come to believe that the Banebots transmissions are the easiest and best methods to get useful work out of a FP motor.
Read this thread: Fisher Price Motor Replacement Gearbox
for more good discussion around using Banebots transmissions with FP motors.
Joe J.
Team #88, TJ2
Unread 11-01-2007, 18:04
George George is offline
#0060 (Bulldogs)
George is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to behold
Hay ALL
Dumb Question, is one or two fisher price motor/gearboxes?
Check list said 1, we got 2 in the kit, or did I read the list wrong?
Geo.
P.S use a octagon drive adaptor, a hose clamp, and support the outboard shaft with a bearing.
watch the oz, the lbs take care of themselfs
Unread 11-01-2007, 18:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Update #1 says the checklist is incorrect. Everyone received and we are alllowed to use two (2) Fisher Price motors/gearboxes.
EDIT: Lil Lavery beat me to it.
Unread 13-01-2007, 11:09
GramNegative GramNegative is offline
FRC #1816
GramNegative is an unknown quantity at this point
I have a question about calculating the max power of the Fisher-price motor. I made a spreadsheet to redo the motor data from the "Tips, Guidelines and Good Practices" chart so that all of the units were consistent (Nm for torque and rad/s for speed).
I keep getting calculations that are not even close to the information provided and when I went to do it by hand I encounter the same problem. So, for example, I was fairly certain that the fisher price max power should be attained like this:
max power = (torque at stall divided by two) times (free speed divided by two)
Pmax = (T0/2)*(Wf/2)
T0 = 417.7 mNm * (.001) = .4177 Nm
Wf = (15636 RPM * 2 * pi)/60 = 1637 rad/s
Pmax = (.4177/2)*(1637/2) = 171W, as compared to 387W published
Which is so off that I've rechecked my work multiple times but cannot find any error.
Also, regarding the octagonal drive adapters for the FP gearboxes (mentioned by George), where are those available for purchase?
Unread 13-01-2007, 11:20
burkey_turkey burkey_turkey is offline
AKA: Andrew
FRC #0422 (MechTechs)
burkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to beholdburkey_turkey is a splendid one to behold
I have a question about the bigger fisher price motors, the CIM FP801 (What my team calls the 'pimp CIM'). It comes with a gear on it already, as well as that springy thing. we took the springy thing off and want to just use the motor with that gear already on it. so my question: what are the dimensions and specs of that gear? it has 16 teeth, i know that much, but if i want to fit a McMaster Carr Gear to it i will need to know more. a link to some specifications or some details would be greatly apreciated.
Unread 13-01-2007, 11:21
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
You're right. See this post:
http://www.chiefdelphi.com/forums/sh...98&postcount=3
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 13-01-2007, 11:23
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
See this post:
http://www.chiefdelphi.com/forums/sh...1&postcount=21
(The "gear" is actually a belt pulley, and probably won't interlock with other gears.)
_
Unread 14-01-2007, 23:50
AKA: Andrew
thanks. i thought that didnt look like a spur gear....
So saturday we were trying to get it off because we didnt want it on there (the belt thing). we successfully got off the spring roller atachement in seconds. the belt thing was a disaster. we took off the black clip on top as well as the other shiny protective thing. then we took off the set screw that was ataching the belt thing to the output shaft. we couldnt think of anything else to unatach in order to get off the belt thing. so we pulled and yanked for an hour or so on the belt thing trying to get it off. that didnt work at all. next we tried to grind it. we have a nice picture of this somewhere actually, because we ground off about a third of the belt thing. since we could see about half of the shaft now, we grabbed the belt thing with some vice grips clamped to a table, and started hitting the output shaft with hammer hoping to coerve it into moving the entire motor assembly down while the belth thing stays still, thus moving it off. somehow, we managed to hammer the output shaft out the back of the CIM ruining it.
so thats the sad story of our pimp CIM. we are ordering another one because we need that motor. hopefully we can order it without that stupid belt thing, but i dont know. if we cant get it without, can someone who has successfully removed the belt thing post instructions on how to effectively remove it without damagint the CIM? thanks.
pictures to come i promise!
Unread 14-01-2007, 23:57
in between teams
AKA: Luke Van Oort
There have been many posts about it (searching is a wonderful thing), the pulley is held on with an epoxy adhesive that weakens greatly when heated. Last year we used a Bunsen burner to heat it, but other methods work fine. After the epoxy has been weakened it can easily be pried of with a screwdriver or pulled off with a gear puller.
Team 1219: 2009 - Mentor
Unread 14-01-2007, 23:58
Gdeaver Gdeaver is offline
FRC #1640
The belt thing is glued on. To remove it you will need a gear puller an a small torch to heat the belt thing up to about 400 F. Attach the gear puller and put some tension on it. Begin heating the pulley. When it gets hot enough, you will be able to turn the gear puller very easily and remove the pulley. There is a thread discussing this from last year.
Unread 15-01-2007, 11:43
Tom Bishop's Avatar
Tom Bishop Tom Bishop is offline
FRC #0832 (Oscar)
Tom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant future
Definitely invest in a gear puller. We have a small one (for FP's and similiar) and a larger one. It will save you much aggravation, not to mention motors!!!. Mcamaster carries them and BB has a nice small one.
Fisher Price Motors MechaJagEric Electrical 3 13-02-2003 08:45
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
fisher price motors archiver 2000 4 23-06-2002 22:36
4 fisher price motors? Jordan A. General Forum 2 12-01-2002 11:52
