Go to Post "We've got more money than brains." - Travis Hoffman [more]
Unread 14-01-2007, 23:10
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
<R91>
<R91> Each motor, actuator, and compressor must be connected to one, and only one, speed controller or relay module.
This wording leads me to believe that you can not connect 2 spikes to a solenoid but you could connect 2 solenoids to a spike.
I believe their intent was to say:
Each speed controller and relay module must be connected to one, and only one motor, actuator, or compressor .
It makes a big difference.
Unread 14-01-2007, 23:19
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: <R91>
Or perhaps they're actually telling you that you cannot use more than one speed controller.
But that'd be bupkis.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 15-01-2007, 00:22
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: <R91>
Actually, it makes perfect sense the way it is. This way, motors/compressors cannot be connected straight to power sources - they must be connected to a speed controller or relay. And you cannot double up the speed controllers/relays to create parallel circuits to power the motor in an attempt to double the available amperage.
If it was the other way around, as suggested, then every speed controller would have to be connected to a motor. But motors would not have to be connected to speed controllers - which could lead to big problems.
-dave
Unread 15-01-2007, 00:43
RebAl's Avatar
Re: <R91>
-dave
I see what your saying. So the intent of the rule was to make sure that each motor, solenoid, etc was connected to the appropriate control apparatus.
Specifically, I was thinking of using a single spike to drive two single action solenoids (such as the Festo) as shown in the attached picture. This is from the spike manual. However, a post on the Q&A forum disallows this type of usage, hence the confusion.
EDIT: It appears that the question I am referring to has been removed from the Q&A forum.
Unread 15-01-2007, 00:55
AKA: Dr. Brooks
no team (WRRF)
Re: <R91>
This configuration of a single pike controlling two solenoids was an allowed wiring configuration in [possibily distant] past seasons. Keep an eye out for the QandA item. Answers in the QandA are subject to change.
Eugene
Unread 15-01-2007, 11:15
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: <R91>
By the way, when talking about solenoid VALVES, it is probably best to call it a solenoid valve rather than just a solenoid. This will help reduce confusion about just what you are refering to. There are other sorts of solenoid actuators that are specifically prohibited, or at least have been in the past.
We wouldn't want the freshman and rookies to get confused about what is allowed and what is not.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 15-01-2007, 20:53
RebAl's Avatar
Re: <R91>
This has been addressed: http://forums.usfirst.org/showthread.php?t=1292
