Go to Post We can help make those dreams, maybe. ;) - Adare180 [more]
Unread 13-01-2007, 22:54
FreakyAntelope's Avatar
FreakyAntelope FreakyAntelope is offline
Unregistered User
AKA: Toby Waite
#0246 (Overclocked)
Team Role: Electrical
FreakyAntelope will become famous soon enough
Send a message via AIM to FreakyAntelope
Custom PWM Cables and R69
We are planning on making our own PWM cables this year, rather than buying the expensive ones from IFI, as I know teams have in the past. R69, however, states that "... Every speed controller and relay module must be connected via PWM cable to the Robot Controller...".
I assume that this rule is about the signals, and not the actual cables, but I wanted to check to make sure everyone else was reading it the same way I was. "PWM cable" does not need to be the exact cable purchased from IFI, so long as it is the correct AWG (by R90), and has the correct crimp connectors on the ends, correct?
By the way, if you are looking into making PWM cables yourself, I found that newark.com had much lower prices than digikey on the pins and housings, although they did not sell the molex crimper.
Thanks,
Toby
Unread 13-01-2007, 23:13
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Custom PWM Cables and R69
Thanks,
Toby
PWM is a reference to the pulse-width modulated signal, and does not refer to any particular brand of cable. So long as your wire gauge is at least as big as the IFI cables, you should be fine.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 14-01-2007, 19:51
Thanks,
Toby
Toby,
The PWM cables are available in any length, from almost any hobby shop in the country. Many teams make their own by buying 3 conductor ribbon cable and the appropriate housings. Newark does sell these items and the crimper but (and this is a big one) the Newark minimum order is beyond most teams. I believe at last count is was $125 not including shipping. Even I have stopped buying from Newark (at work) for most parts due to the high minimum.
Unread 14-01-2007, 20:25
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
there aren't any rules about cutting the cables and splicing them to make them shorter are there? im trying to make a very nice control board layout this year so its easy to explain to the newer members on our team.
/forest
Unread 14-01-2007, 21:42
DonRotolo's Avatar
Back to humble
FRC #0832
Try http://www.chiefdelphi.com/forums/sh...5&postcount=26, good source for pins and bodies.
For 24 ga or 22 ga 3-conductor wire (made by HiTec), search eBay for "Servo Wire", or any R/C hobby shop will have it or can get it in a few days. About $15 for 50 feet.
Radio Shack sells a crimper - 276-1595 - that crimps these pins perfectly. $11.
Don
Unread 15-01-2007, 07:28
/forest
No,
There is no rule about splicing. However, why add another source of possible failure. If a PWM is too long, you can fold it back on itself and use a tiewrap to make it neat. If you have to move the device to which it is connected then you have to replace the cable anyway.
Unread 15-01-2007, 09:57
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Don
Here is another ChiefDelphi.com thread that has sources a for pins & housings and crimpers to make your own PWM cables.
Joe J.
Team #88, TJ2
Unread 15-01-2007, 11:18
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Thanks Don and Joe! Our crimper and connectors seem to have "sprouted legs and walked away". I was just thinking about replacing them...
Don't PANIC!
S. P. A. M.
Unread 15-01-2007, 14:12
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
I've had good luck with the folks at Hansen Hobbies: http://www.hansenhobbies.com/products/connectors/
Custom-length PWM cables really clean up your robot's wiring. And if you need longer cables, this is the best solution (two PWM cables end-to-end is asking for trouble).
Unread 15-01-2007, 14:22
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
We've used www.HansenHobbies.com ourselves about 3 or 4 times for such. Very reliable and quick to ship, except for one time when it took 3 weeks.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 15-01-2007, 14:28
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
I have a different question regarding the PWM cables. There are three wires,
White-Signal
Black-Ground
red- +5V
In other robotic projects I'm able to wire my ESCs using only the White cable. Which is really the only thing that the RC needs to see. I was wondering if this is legal or not in first (to use only the white wire that is)
--Dan
Unread 15-01-2007, 15:06
Daniel,
The speed controllers do not use the 5 volt wire but do use the signal wire and ground. I am having a brain cloud on the Spikes, but I believe all three wires are in use but the relay outputs are different than the PWM outputs on the RC. The servos use all three. I would prefer to use the standard PWM cable for all three and have standard wiring throughout the robot.
Unread 15-01-2007, 15:16
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
You are correct. You've got ground, forward, and reverse. I honestly couldn't tell you which is forward and reverse, but I know all three are in use.
I don't think that it's a good idea to use 1-wire or 2-wire PWM cables because it's non-standard and I'm not sure if it would cause the parts to malfunction. It's not worth the risk; you don't gain that much weight from leaving the PWM cables alone.
JBot
Aren't signatures a bit outdated?
Unread 15-01-2007, 15:17
Phalanx's Avatar
Daniel,
The speed controllers do not use the 5 volt wire but do use the signal wire and ground. I am having a brain cloud on the Spikes, but I believe all three wires are in use but the relay outputs are different than the PWM outputs. The servos use all three. I would prefer to use the standard PWM cable for all three and have standard wiring throughout the robot.
The spikes use all 3 wires. The red and white wire are for the fwd and rev signals. The black is ground.
Unless the device needs +5volts of power, then only the ground and signal wires are needed.
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
victors spikes and pwm cables sburro Electrical 3 23-02-2005 02:24
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
