Go to Post Stop making me want to spend money on books! I don't need any more good influences in my life!!!! - FourPenguins [more]
Unread 15-01-2007, 07:42
Re: Question about the bumpers.
Brad,
The bumpers last year were one of the most discussed and complained about system. I would ask yourself this question. 'If I use the bumper and the mounting hardware I use fails on one side, what will happen?' I think you will see that a failure of this type will severely limit the function of your robot and it may be disabled if there is a threat of carpet damage. At most you will be asked only twice at each event to remove the bumpers for weigh in so make them secure.
Unread 15-01-2007, 08:16
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
my big question about bumpers is.. Do you have to have them on your bot? It says "Strongly Encouraged" but it doesn't say its mandatory. And What if you made a bumper that only covered part of your bot?
Unread 15-01-2007, 08:22
BillP's Avatar
BillP BillP is offline
AKA: GreenBeard
None #0624 (CRyptonite)
BillP is a jewel in the roughBillP is a jewel in the roughBillP is a jewel in the rough
No, the bumpers are not mandatory, and yes, it is OK if they only cover part of your robot. However, if you don't have the bumpers, the referee's may interpret "contact" with other robots differently (this varied a little from regional to regional last year).
Having said that, I'm pretty sure you can put a different bumper design on your robot, but if you do, they must be weighed as part of the robot and fit inside the sizing cube. (Only the "Standard" bumpers must be removed for weighing and sizing). This is just my interpretation. You might want to confirm this with the Q/A system.
Unread 15-01-2007, 08:33
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
I think that it would be in your best interest to just use the bolt and fastener system, and if you find out anything new to change it later. "Better to be safe then drilling new holes in your frame to fit screws and bolts" I always like to say! But seriously though... I think that with the hundreds of complaints and other problems that FIRST had last year with the bumper system, They are most likely assuming that you remember the rules last year, and will lay down the law on your team when the inspection time comes for your robot. I would make sure that you always build a robot that will not draw any negative attention toward your team. Doing so, will usually result in further problems and negative tension toward your robot. So it’s better to be safe then sorry, just go with your gut instinct.
Unread 15-01-2007, 08:51
FRC #1360
Thanks. I wanted to clarify that. And for the record I understand ref will look at bumping in a different light without bumpers, thats why it will be partly covered, so far our design cannot have a bumper on the back of it. So we will probably put one on the front for bumping purposes.
EDIT: Is it still considered to be a "standard bumper" if it doesn't completely cover the robot?
Unread 15-01-2007, 09:23
Bumpers do not need to be on all sides of the robot. If your design requires you be able to scoop tubes from the floor, then a bumper would not allow that. The object with bumpers is that field refs will be watching for contact within the bumper zone as well as other rules relating to the competition. If you use bumpers, then they must be built using the construction guide in the robot manual. (i.e. two unmodified pool noodles on a plywood backing covered in the specified fabric, etc.) If they are not detachable then their weight and size will be included in the robot max dimensions and weight during inspection. By using the bumper design, you can legally pick up another 15 lbs and provide some protection for your robot. I predict this year will be a very defensive year, plan on pushing and bumping.
Unread 15-01-2007, 11:20
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Hm, thanks guys. The zipties were obviously an exaggeration, I didn't mean we actually plan to use them. We were just trying to think of an easier way to secure the bumpers, but we probably will end up using the bolts still. They were just a real hassle last year, because we planned them last minute. I'll tell our build team that they should try to use the bolt system, and just try to make it easier to reach. Anyways, thanks again.
Unread 15-01-2007, 13:53
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
I feel you on the bolt system. Our chassis will have big milled channels for weight on the sides, so we have nothing to bolt them to. Looks like I'll have to custom engineer something when we actually have a robot to look at.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 15-01-2007, 15:41
EricH EricH is online now
Easy use of bolts: use a t-nut (blind-nut) on the inside of the bumpers (well secured--you don't want to have to take the bumper apart to find it) and put a hole through the frame and bumper backing (and cloth as well) for the bolt. When you take the bumpers off, attach the bolts to them so you don't lose 'em. If you have something on the outside of your robot, like an axle end, try shaping a small hole/cavity for it. (Then mark which side that bumper goes on and which side is up.)
Unread 15-01-2007, 15:44
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
hey but if you use the bumpers from last year you shouldn't have any problems
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 15-01-2007, 15:56
Ah, but are they component or mechanism? You could make a case either way.
Unread 15-01-2007, 16:02
Billfred's Avatar
Billfred Billfred is offline
That issue is a moot point--they're FABRICATED ITEMS under the rules.
Unread 15-01-2007, 17:07
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
There is a Q&A about this that makes it quite clear that you are required to make new bumpers this year.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 16-01-2007, 07:28
I inspected a team at Championship that attached eye bolts to the back side of the bumpers. They fit over a couple of threaded studs on the robot base and attached with butterfly nuts. An easy, no tool solution with gravity working in their favor.
Question about the playfield Big H General Forum 2 19-02-2004 07:57
Question about the goal archiver 2001 1 24-06-2002 00:24
Question about the bridge archiver 2001 11 23-06-2002 22:54
Question about bumpers Randy_Ai Technical Discussion 2 23-01-2002 17:59
