Go to Post Teams that TRY to win and TRY to do their best end up having students that learn more, learn the value of hard work, and are inspired by the process. - Chris Hibner [more]
Unread 15-01-2007, 08:33
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: Question about the bumpers.
I think that it would be in your best interest to just use the bolt and fastener system, and if you find out anything new to change it later. "Better to be safe then drilling new holes in your frame to fit screws and bolts" I always like to say! But seriously though... I think that with the hundreds of complaints and other problems that FIRST had last year with the bumper system, They are most likely assuming that you remember the rules last year, and will lay down the law on your team when the inspection time comes for your robot. I would make sure that you always build a robot that will not draw any negative attention toward your team. Doing so, will usually result in further problems and negative tension toward your robot. So it’s better to be safe then sorry, just go with your gut instinct.
Question about the playfield Big H General Forum 2 19-02-2004 07:57
Question about the goal archiver 2001 1 24-06-2002 00:24
Question about the bridge archiver 2001 11 23-06-2002 22:54
Question about bumpers Randy_Ai Technical Discussion 2 23-01-2002 17:59
