Go to Post "By three ways we may learn wisdom: first is by reflection, which is noblest; second by imitation, which is easiest; and third by experience , which is the bitterest." - bEdhEd [more]
Unread 15-01-2007, 09:54
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: PWM 13-16 Replacement Code Beta Test
Originally Posted by Kevin Watson View Post
Like Generate_Pwms(), my code only generates one pulse on each of the four outputs each time it's called. If called from Process_Data_From_Master_uP(), the update rate is ~38 Hz. Typical servos won't handle a rate much higher than this, but the Victors are okay to at least 100 Hz.
-Kevin
Ok, so does that mean you can not call it in the fast loop? If this is the case, is there an advantage to using PWM's 13-16? If the outputs can only be updated every 26.2 ms (38Hz) For example if I wanted to use 13 and 14 for camera servo control, to move 200 steps would take over 5 seconds if it moved in one step increments (200 * .0262s). I really would like to see the camera "snap" to a position. It seems that nasty little 26.2ms loop time keeps getting in the way.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 15-01-2007, 12:55
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Yes, you could call it in the fast loop to control your Victors at a higher rate for applications like position control (which generally works better at rates greater than 38 Hz). You'll need to synchronize the updates to a timer or some sensor like a gyro.
I've already enumerated some other advantages above.
Your searching algorithm needs tuning. The camera has a fairly wide field of view, so I think you could use a much larger step. I would step in 30 degree increments, wait a bit for the camera to send a t-packet (or two) and then either start tracking, or step another 30 degrees... If you're using my code, these are built-in parameters you can tweak.
For grins, I used digital servos (not FRC legal) with my code and after modifying tracking.c a bit, I can find a green light and start tracking in somewhere between one and two seconds, without the software having any a priori knowledge of where the light is located. I suspect nearly the same level of performance can be had with the HS322HD servos.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-01-2007, 15:53
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Kevin,
I would expect that the code should work fine. We (1126) used my version throughout the 2006 season without any issues. Your increase in gain from 40 to 50 is probably a good idea, as we found one of the Victors did not quite go to maximum at the high end (2 msec) without recalibration. The additional 25% on range should easily eliminate this potential problem. You may want to think about modifying your "temp_pwm_xx" calculation so it doesn't require the signed int multiplication. This adds a fair amount of execution time to the routine (relative to how quick it could execute, not to overall processor usage which is extremely minor). It also requires the use of the MATH_DATA section so if someone ever wanted to use the routine from within an interrupt (why? I don't know, but I never rule anything out), they would need to save that data section. I do like the addition of the CENTER & GAIN options it allows for much more flexibility.
Mike
Unread 15-01-2007, 16:03
AdamHeard's Avatar
Lead Mentor
So... is the legality of this confirmed?
-Adam
Unread 15-01-2007, 16:47
FRC #2429
-Adam
There are no rules preventing teams from using this code, so there is nothing to confirm. If you're thinking that this somehow gets around the ability to safe motors, it doesn't because IFI's mechanism for doing that is under the master microcontrollers control.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-01-2007, 17:33
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
-Kevin
I'm curious how that works, since the pins are supposedly connected straight to the user processor, how would the master processor disable that?
Also, how did you get around the interrupt-glitch thing? I'm missing something obvious when I look at the code...
Matt Krass
Unread 15-01-2007, 17:43
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Most likely the PWM outputs from the user processor run through a buffer with an enable line, and the master disables the buffers when the robot is to be disabled, which tri-states the buffer outputs.
Unread 15-01-2007, 18:01
JSonntag JSonntag is offline
FRC #0486 (Positronic Panthers)
JSonntag is on a distinguished road
Send a message via AIM to JSonntag
He disabled the interrupts when the pwm's transition from low to high
Unread 15-01-2007, 18:17
FRC #2429
They aren't connected directly (which is why you can't use them as inputs). There is a switch that is controlled by the master that determines which processor gets to send its output to the pin. The call to Setup_PWM_Output_Type() tells the master processor who's in the driver seat (icky pun intended). When your 'bot is disabled, the switch is flipped to the master, which provides the 1.5 ms neutral pulse.
Edit: Actually, Dave's explanation may be closer to the truth. If the master is capable of generating the PWM output, why do we have the Generate_Pwms() kludge to deal with. Still, the 1.5 ms PWM neutral pulse needs to get generated for safety reasons. If not the master, who?
The pulse doesn't glitch because once software sets up the timer and CCP hardware and says go, everything is done in hardware, which is oblivious to the interrupts firing-off in the background.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-01-2007, 18:27
Software Engineer
Rookie Year: 1995
If you're talking about when the robot is disabled, I'm pretty sure the PWM pins are left floating. We noticed a side effect of this last year when we ran some servo wires close to our RS232 for the camera, and when the robot was disabled the RS232 would generate enough noise on the (floating) PWM line to cause our camera servos to twitch. Actually, now that I think about it, if those PWM wires had been connected to a Victor, it could have been a dangerous situation. When the robot was enabled, the PWM output was being driven such that noise was not an issue.
Unread 15-01-2007, 18:32
FRC #2429
Ugh, floating the PWM outputs doesn't seem like a good idea. Thanks, I stand corrected.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2007, 13:38
maniac_2040's Avatar
maniac_2040 maniac_2040 is offline
AKA: Matt
FRC #3302 (Turbo Trojans)
maniac_2040 is infamous around these partsmaniac_2040 is infamous around these partsmaniac_2040 is infamous around these partsmaniac_2040 is infamous around these parts
Send a message via MSN to maniac_2040
I've been seing something similar to this when testing on our robot. I was using some Vex Motor Modules to test some code. When I would put the controller in the program state to download, sometimes the motor would just randomly spin in all kinds of directions, and I would usually have to unplug the backup battery if it didn't stop. Does this pwm code fix that? I would like to know more about these "floating" pwms. When I start testing with our arm mechanism it will be very dangerous if the arm can just start randomly swinging around in the prog state...
Unread 21-01-2007, 16:31
FRC #2429
IMHO, one of the nice things about this software is the ability to define how the PWM range of 0-255 maps to the servo position range. So for fun, I decided that I'd like to wring-out as much pointing accuracy from my camera's tilt mechanism by mapping the entire 0-255 PWM range to the more useful 0 to 90 degree tilt range. These are the steps I took:
1) Moved the tilt PWM from PWM output 2 to 16. This is necessary because PWM() can only contol PWM outputs 13 through 16.
2) The first piece of information I needed was to find the PWM pulse width that caused the servo to rotate the camera to the 90 degree position. Using the camera software's interactive PWM adjustment menu to command the tilt mechanism to rotate the lens up, I found that the default gain of 5.0 us per PWM step wasn't high enough to rotate the camera to the 90 degree position. I opened up pwm.h and increased to gain on PWM output 16 to a value of 70 for a pulse step size of 7.0 us. I re-compiled and downloaded the code to the RC and found that I could command the servo to 90 degrees with a PWM value of 254. Using the inverse of the algorithm from PWM(), I calculated that PWM() was sending a PWM pulse width of 2.389 ms.
3) Using the same technique described above, I determined the pulse width I needed to send for 0 degrees to be 1.479 ms.
4) I then calculated the pulse width range that I needed to cover by subtracting the result of #2 from #3 for a range of 0.910 ms.
5) To calculate the gain, I just divided the pulse range needed by the available PWM range of 256 for a gain of 36 or 3.6 us per PWM step. This is the gain value that is needed to limit the range of servo motion to 90 degrees.
6) I now needed to calculate a new center point for the servo. If I leave it at 1.5 ms, the servo will rotate through a 90 degree range, but it will be -45 degrees to 45 degrees. I needed to change the center point to +45 degrees so the servo will rotate from 0 to 90 degrees. To calculate the new center point, I just divided the range (from #4) by 2 and added that to the 0 degree pulse width (from #3) for a value of 19340 (or 1.934 ms).
7) Plugging the values from #5 and #6 into pwm.h, re-compiling, loading the RC, and then testing, I found the range to be the desired 0 to 90 degree range!
8) I then changed the PWM value to angle code in terminal.c from:
printf("Tilt Angle (degrees) = %d\r\n", (((int)TILT_SERVO - 144) * 25)/50);
to:
printf("Tilt Angle (degrees) = %d\r\n", ((int)TILT_SERVO * 90)/250);
9) The tilt gain was then changed from 8 to 4 for faster tracking.
10) Because I now have better pointing ability, I was also able to change the TILT_ALLOWABLE_ERROR_DEFAULT value to 3 pixels.
11) Finally, I changed the min tilt PWM value to 0, the maximum to 250 (255 is a degree or two past 90), adjusted the mid-point to 50.
This new found pointing accuracy might come in handy if you're using the green tracking light for navigation.
-Kevin
Kevin Watson
http://kevin.org
Unread 21-01-2007, 18:05
Using the Bells & Whistles camera code, PMWs 13-16 twitch for a moment when data is stored to EEPROM. I can work around it easily, but it's definitely undesired operation.
Unread 21-01-2007, 19:58
FRC #2429
Yeah, I noticed it this morning. I suspect the menu drawing code is using too much of the CPU and the servos are trying to return to the center position when they don't see a pulse for a while.
-Kevin
Kevin Watson
http://kevin.org
Vex start up code run PWM outputs without Rx intellec7 Programming 3 05-05-2006 23:29
Pwm 11, 12 and CMU code Chris Bright Programming 3 01-02-2005 19:34
Victor Replacement JamesCH95 Electrical 4 15-12-2004 20:12
Replacement Parts archiver 1999 0 23-06-2002 22:01
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
