Go to Post Those four stages will most likely be supplanted with the more aptly named phased approach: "Don't Panic", "Consider Panicing" and "Why havent we been panicing?" - Dan Richardson [more]
Unread 07-01-2007, 18:26
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
Inventor (need help starting)
Hey! I just joined the forums...
I want* to learn inventor because the person who used it last year graduated. I was hoping that someone could tell me where I should start or suggest any tutorials because I have to learn this program within a week. I do know how to use autocad
Unread 07-01-2007, 18:38
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: Inventor (need help starting)
One of our team members began using the software in the beginning of the build season. He spent about 3 hours doing all the tutorials, and now he is one of the better members on the team. Just do every tutorial, or at least the ones that you think you need, and just practice. If there is a time where you can't find anything to model, just come up with something that you think would be enjoyable to make.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 07-01-2007, 20:34
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
I'd say the same thing.
The Help catalog in Inventor (from Help menu) is how some of our Tech Ed program's most successful CADers became successful.
FIRSTbase (the website where teams can download the software - if you don't have a username, ask your team main contact/mentor to add you) has training materials: http://firstbase.autodesk.com
Also look in the Inventor folder on the computer:
C:\Program Files\Autodesk
Inside Autodesk is an Inventor or Inventor 11 folder. Then look for a PSS folder which will contain a few PDFs:
Adsk_Inventor_11_GetStart.pdf will help you learn step by step all of the functions involved with part modeling, assemblies, and drawings.
AIProf_11_RoutedSys_GetStart.pdf will explain how to use Tube & Pipe and Cable & Harness
AIProf_11_Analysis_Simul_GetStart.pdf is for Stress Analysis and Dynamic Simulation
Sean Dotson's site has a ton of tutorials for more advanced things: http://www.sdotson.com/tutorials.asp
J.D. Mather's site has tutorials for surface modeling/complex shapes: http://home.pct.edu/~jmather/content..._tutorials.htm
Autodesk's website also has some intermediate to advances tutorials.
Now, the AIProf guides and advanced tutorials would take a LONG time to get a working knowledge of because it's so involved. Unless you have a number of hours every day this week and a lot of patience, I recommend just using the FIRSTbase training materials for now so you have enough time to model the robot.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 07-01-2007, 20:37
CraigHickman
Posts: n/a
Do every tutorial in sight, and every one you can find. Also, your wording strikes me... I personally view it as you get to learn Inventor, not you have to. This program is wonderful. Once you've taken all the tutorials, just grab something around the house and try and model it. That's one of the best ways to learn to do obscure items, which will aid you in modeling the mundane.
Unread 07-01-2007, 20:41
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
The tutorials built in are very good. About two years ago when I first started to use the program the tutorials gave me a good understanding of how to use Inventor. The key components of the program are all you need to know, and once you know them, it becomes second nature and you are limitless in the stuff you can build and create.
Unread 08-01-2007, 11:09
rohit's Avatar
Inventor Person
Thanks for all the help! All the tutorials are helping me a lot.
And thanks for the website worldbringer. I always wanted 3ds Max but there weren't enough licences. And I had to chose between that or Revit, but I picked Revit. Now I can have both!
Unread 08-01-2007, 13:52
Erro's Avatar
Erro Erro is offline
Chairman's Team Student Leader
AKA: Will H.
FRC #0365 (Miracle of Engineering)
Erro is an unknown quantity at this point
Most useful stuff has already been said, but here's one pointer I've picked up from my rather exhaustive use of Inventor- if you are using stock metal pieces (ie. Bosch) in your designs, the companies often have models you can download from the website. It saves a lot of time.
Enthusiastic (and often exasperated ) former captain of MOE 365 Chairman's Award Presentation Team...
Willy the Wandering Turtle (don't ask me where I picked that one up- it's a long story)...
Check out the blog at http://politicalhumorscience.blogspot.com
Unread 12-01-2007, 15:18
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
Unread 15-01-2007, 12:34
Robert Thacker-'s Avatar
Robert Thacker- Robert Thacker- is offline
2007 Autodesk Inventor Winner
FRC #0836 (RoboBees)
Robert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the roughRobert Thacker- is a jewel in the rough
If you ever need help, email me or send me a private message. I would be more than happy to help with any problems or questions you may be facing.
skywalker2d@gmail.com
Mentor on FIRST Team 836: The RoboBees
Alumni Team 103:
2005, 2006, 2007, & 2009 National Autodesk Inventor Award Winner
Unread 15-01-2007, 17:27
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
If you already have a knowledge of AutoCAD, you may be able to get a head start by importing in some of your sketches also.
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 15-01-2007, 18:19
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
it is also good to try drawing something out of a mechanical design text book and find a detail drawing (i picked out a vise). Unlike that something you just pick up it will have all necessary dimensions if you need help email me at Bballda88@aol.com
Unread 15-01-2007, 19:15
Mechanical/Driver
Basics of all CAD:
If you took something, no matter how complex, and just forced it into a 2d flat image, thats what you need to sketch. Add dimensions and features (extrude, revolve), and voila, you've got your starting point. Then add detail work like more extrusions, cuts, holes, fillets, chamfers, etc.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 15-01-2007, 19:33
There is a book that just came out for 3D Inventor Parametric drawing. You'll love it! It's called "Parametric Modeling Using Inventor" by James P. LoFaso. I looked at it and I thought he did a pretty good job at explaining the program. I would have done some chapters differently (just the organization on how he builds information).
Best of Luck!
Alumni Team 103:
i need some help in inventor... Alex Cormier Inventor 8 28-01-2004 21:33
I need help in inventor Nick R. Inventor 4 14-10-2003 08:04
HELP!! i need help starting a new team!! shyra1353 Starting New Teams 18 07-10-2003 17:55
Need to import robot made in inventor into 3dsmax, HELP! anish 3D Animation and Competition 1 03-03-2002 13:53
Need help In Autodsek Inventor PhillyRobotics Inventor 8 27-12-2001 07:57
