Re: Configuring Labview code to easyC
Once you load the labview file into easyC it will save those values in the current project.
But doesnt it have to be saved as a easyC format to do this in the first place???
Oh, I get it, can you e-mail me that file to amartin "at" intelitek.com
I sent out the email to your email
When you guys get your issue resolved, do you mind posting your results?
-Danny |
Labview changed the file to a .ini from a .ecc. So just rename the file labview generates to a .ecc and easyC will load it. We will update easyC in the next build.
| easyC Mechanum Drive Code | Kingofl337 | Programming | 0 | 12-01-2007 23:48 |
| EasyC: Execute code before autonomous | Greg Marra | Programming | 7 | 07-01-2007 21:30 |
| EasyC Default Code | Team 1649 | Programming | 13 | 29-01-2006 11:52 |
| LabView Gear Tooth Sensor Code | SkiRacer | LabView and Data Acquisition | 2 | 17-01-2006 03:53 |
| VS.NET 2003 Configuring | D.Viddy | Programming | 5 | 20-01-2004 21:24 |
