Go to Post Without programmers there would only be a robotic beauty contest. - mallot1243 [more]
Unread 15-01-2007, 13:21
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
V13 Master Code
Here is the new version of the master code for the 04-07 controllers.
Unread 15-01-2007, 16:02
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: V13 Master Code
How do you update the master code in the robot controller?
Unread 15-01-2007, 22:49
Kingofl337's Avatar
AKA: Adam
Re: V13 Master Code
In easyC goto the terminal window then under the options menu select "Update Master Code" then specify a path to the .bin file.
In the IFI loader just hit browse and then select .bin for the file type and specify the path to the .bin file.
Need: Master Code JamesBrown Programming 1 09-01-2007 21:53
Master Code 11? SteveO Programming 5 22-04-2005 19:48
Master Code? HolyOne207 Programming 4 12-01-2005 22:32
2005 RC Master Code or yaniv Programming 8 12-01-2005 12:05
