Go to Post You inspire your way. I'll inspire my way. - Andrew Schreiber [more]
Unread 15-01-2007, 16:06
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Solenoid feedback or Sensor?
I don't know much about pneumatics so my question is, does the solenoid have a feedback function that tells us in what position the linear actuator is? do we get any sensors with the kit? Im asking because say you have the pneumatics hooked up to lift your arm, you don't want it to slam to it's full position and then slam back onto the robot.
Thanks
Vova
Unread 17-01-2007, 00:33
Thorcat Thorcat is offline
FRC #1540
Thorcat is an unknown quantity at this point
Re: Solenoid feedback or Sensor?
There is no sensor in the KOP, but a magnetic sensor option is avaliable from Bimba. this sensor is only useful for finding when the actuator has reatched it's limits. If you only want to ensure that your actuator does not travel at breakneck speeds, you will want to use a restrictor valve.
Unread 18-01-2007, 00:22
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Yes you can order magnetic versions of the cylinder, but if using the mag sensors provided, you still only get two positions indicated, via switch closures.
Better ways:
1) If the pneumatic is operating an arm pivot, contrive a way to attach a 100K linear taper potentiometer to the hinge of the operated joint. They're available in both single turn and multi-turn, so I've always been able to gear one up appropriately with hobby store plastic gears, to monitor the joint somewhere near the pivot linkage.
The "pot" is wired into an Analog Input and read. Interfacing and reading a potentiometer is described in the RC manual. (CW travel end = +5VDC [red], CCW travel end = Ground [blk], and center wiper = signal [wht]).
2) If you are monitoring a linear axis, you may be able to:
A) Attach a rack and pinion system somewhere to operate a feedback potentiometer. The rack goes onto the linear axis, and an appropriate sized pinion gear for your desired throw goes onto the shaft of a multi-turn 100K linear taper potentiometer.
B) Use a 100K linear taper "string pot" to "follow the cylinder's action". BUT, there are two problems: (1) With most cylinder apps, if the cylinder is not aligned with the axis of motion, you may now have set a trig problem for yourself. After all, the cylinder's motion is not of interest, the AXIS motion is! It is MUCH smarter to simply follow the axis or joint itself, as described above. (2) I've yet to find a cheap string pot! So although I've used them before in industry, to date I've never done it on a FIRST robot. (I guess you COULD "make one", but I've yet to find an app where that's really worth the trouble. Again, I've always been able to somehow monitor the joint angle or axis directly with a standard potentiometer.)
Does this answer your question?
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Gear Sensor Competition Usage Feedback de_ Electrical 6 15-05-2005 15:15
solenoid/spike greencactus3 OCCRA Q&A 1 11-09-2004 09:54
festo solenoid maxgebhardt Pneumatics 19 21-01-2004 23:06
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
Solenoid Wires archiver 2001 2 24-06-2002 00:56
