Go to Post We have a lot of rookies, and I can't wait to see the inspiration on their faces. - Karibou [more]
Unread 13-01-2007, 13:47
AuroraAlpha AuroraAlpha is offline
FRC #1525
AuroraAlpha is an unknown quantity at this point
Automattic Controls
For our control board my team is looking at having only four buttons, and each of those buttons would translate into a common spot for picking or placing tubes. We are also planning a small toggle switch so the position of the tube controller can be moved slightly off the presets.
Do you think this is enough to control the vertical effects of an arm or do we need a manual override so that the arm can be moved to any point by a human?
Unread 13-01-2007, 13:54
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: Automattic Controls
If you are relying on potentiometer feedback or some other kind of sensor for closed loop control of your arm's position, always remember, these devices can fail (or get ripped off your bot if they aren't properly protected). It's always a good idea to have a manual method to control your arm in case your automatic methods malfunction.
Unread 15-01-2007, 16:14
Revolverx7's Avatar
Revolverx7 Revolverx7 is offline
Ninja
AKA: Sanders
Team Role: Driver
Revolverx7 is on a distinguished road
Send a message via AIM to Revolverx7
Potentiameters do slip which would move all of your presets to different positions, so its a good idea to have a manual overide.
Like last year we had auto fire mode that was all sensors and then a manual mode that was all human. But you can also mix it up with a sem-auto that uses sensors to get everything in place and then the human makes the final moves.
2006 SBPLI Regional Champions (with 271 & 870)
2006 UTC Finalist (with 181 & 585)
2005 SPBLI Regional Chairmans Award
2005 SBPLI Regional Champions
2005 Philly Regional Finalists
Unread 15-01-2007, 16:19
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
Always have an override, always, like said before, if there are any failures, youll never regret having backups
Blargha!
Unread 16-01-2007, 16:04
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
We had "Boot into Safe Mode" last year that shut off the camera and all the sensors.
Unread 17-01-2007, 15:41
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
We plan to have a switch for manual and auto control. Its always nice to have a manual incase you need it.
Reversing controls? Calvin Programming 10 14-03-2005 22:46
1992 Controls Venkatesh Electrical 6 03-10-2004 22:04
A question of controls Duke 13370 Electrical 8 11-02-2003 14:47
controls great_one411 General Forum 2 02-02-2003 01:03
controls nick_champ_2 General Forum 3 01-02-2003 20:21
