Go to Post FIRST is not all about the competitions. FIRST is about what you learn to get to wherever you got to, whether that be first seed or last. - StephLee [more]
Unread 07-02-2006, 20:21
AKA: Brad
#0190 ( Gompei and the Herd)
Re: New version of WPILib
Originally Posted by Kruuzr
Hi Brad...
I started coding up our full application using WPILib but I ran across a big difference between the documentation and what I assume are new functions. In the userAPI.h file, there are two camera functions:
void InitCamera(unsigned char cameraInitIndex);
void CaptureTrackingData(
unsigned char *centerX,
unsigned char *centerY,
unsigned char *x1,
unsigned char *y1,
unsigned char *x2,
unsigned char *y2,
unsigned char *regionSize,
unsigned char *confidence,
unsigned char *pan,
unsigned char *tilt);
The first is obviously a changed version of InitializeCamera() and the second must be new. Could you give a quick rundown of how they work, especially the 'cameraInitIndex' parameter of InitCamera() ? And how do we set camera parameters as there is no place to set up a CameraInitializationData struct.
Thanks
You caught me! I just put up a new version with the function definition included in the BuiltIns.h file.
There are a few functions in WPILib which are hard for programmers to use, but easy for EasyC to automatically generate. These are two of those functions.
The function:
InitializeCamera(CameraInitializationData *c);
that you can call passing the address of the camera initialization structure. This is probably easiest for you to use. The other function:
was intended for EasyC. It assumes that there is an array of those structs and the argument is the index to the one you want to use.
My suggestion is to initialize a structure with the camera parameters you want to use and call InitializeCamera. It's actually called from inside of InitCamera anyway.
The other functions to use the camera data are:
CaptureTrackingData(...) - this is the one you described
and
TPacket *CopyTrackingData(void);
Is the function that I intended hand-coding programmers to use. This returns a pointer to a static structure containing a TPacket inside of WPILib. When you call the function, it turns off interrupts, grabs the most recent packet, and puts it into the static structure - then returns its address.
Then you can write code like this:
TPacket t = CopyTrackingData();
conf = t->confidence;
which seemed to be pretty convenient.
Brad Miller
Robotics Resource Center
Unread 07-02-2006, 22:14
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
The function:
and
Thanks for the info Brad...
I think the time lag between coding and documentation is a law of physics.
Steve
Unread 07-02-2006, 22:43
AKA: Brad
Steve
The laws of physics change somewhat during the 6 week build season. Then they go back to normal.
Brad Miller
Unread 18-02-2006, 19:00
AKA: Brad
There is a new version of WPILib that has better error handling for the CMUCam. It will now fail more quickly if the camera is not detected and there is a function to get the status from the camera after initialization.
You can get it at the usual place.
Please post something with your results. I have tested it on a 2006 controller with the camera disconnected from the serial adapter and also with the serial adapter disconnected from the robot and both seem to work.
Be sure to save the old version this close to shipping in case you don't like the results.
Brad Miller
Unread 15-01-2007, 16:23
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
michael714 is on a distinguished road
Hey Brad,
Where do you find BuiltIns.h ?
Your efforts are appreciated.
Unread 16-01-2007, 13:50
AKA: Brad
Whoops...
It's fixed now. There was a problem with the automatic build stuff and some stuff didn't update properly.
The new version is in the usual place.
Brad
Brad Miller
Unread 16-01-2007, 14:19
AKA: Steve Cote
FRC #1922 (Ozram)
Not quite fixed yet!!!
I get :
You don't have permission to access /~bamiller/WPILib/WPILib2007011601.zip on this server.
Kruuzr
Originally Posted by BradAMiller View Post
Whoops...
Brad
Unread 16-01-2007, 19:39
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Same here. I'm getting the "You don't have permission to access /~bamiller/WPILib/WPILib2007011601.zip on this server." as well
Unread 17-01-2007, 07:49
AKA: Brad
Fixed... sorry about that.
Brad Miller
Unread 18-01-2007, 22:21
slavik262's Avatar
AKA: Matt Kline
Talking Re: New version of WPILib
Thanks as always
Unread 22-01-2007, 11:47
AKA: Brad
I put up a new version of WPILib that exposes some of the internal functions that can reset the camera and send commands to it. Should make it easy to use the Virtual Window stuff.
http://users.wpi.edu/~bamiller/WPILib/Versions.html
When you reset the camera, then send commands, tracking is turned off. You need to restart tracking by calling StartCamera(). Also you can set the camera debug mode by calling SetCameraDebugMode(1) and the commands to/from the camera will be echoed in the terminal window so you can see what it is doing.
Brad Miller
Unread 27-01-2007, 15:49
slavik262's Avatar
AKA: Matt Kline
Good Stuff. Thank you.
Welcome to the WPILib forum BradAMiller Programming 22 25-03-2008 22:44
WPILib - Library for robot programming BradAMiller Programming 7 21-06-2006 03:12
openFIRST Project Announces Pending Deadline for End of Support for Old Versions Timothy D. Ginn FIRST-related Organizations 0 11-07-2005 22:40
Flash Version of Playing Field Conor Ryan General Forum 49 30-01-2005 20:08
Does anyone know if we can use the version of Backburner from the 3DSMax trial ver? lnxpenguin4ever 3D Animation and Competition 2 26-01-2005 19:58
