Go to Post Maybe next season I want to develop and test a new metric for FRC scouting: Bumper Quality Rating (BQR). BQR-5: The platonic ideal of FRC bumpers. ... BQR-0: Moderate to heavy use of duct tape. I believe BQR would outperform OPR as a predictor of on-field robot performance. - Nate Laverdure [more]
Unread 01-15-2007, 04:10 PM
macwhoo macwhoo is offline
None #2061
macwhoo is an unknown quantity at this point
Sprocket sleeve question
what type of material for the shaft collar can we use so that the spocket does not move on the gear shaft
Unread 01-15-2007, 04:18 PM
Re: Sprocket sleeve question
As in a spacer? As long as it is not explicitly disallowed, your choice. (And I can't find any type of metal or plastic that isn't allowed, provided that it doesn't cost too much.)
Unread 01-15-2007, 04:29 PM
None #2061
Yeah, as a spacer. So you could just use a piece of plastic tubing or something of the sort? (*As long as it isn't disallowed...)
Unread 01-15-2007, 04:33 PM
Yep. Got PVC? If so, you can use it. Or some metal tubing if you wanted.
Unread 01-15-2007, 04:36 PM
None #2061
Yes! Metal tubing might be a bit out of our league, so we'll stick with the PVC. Thanks for the help!
Unread 01-15-2007, 04:40 PM
GeoffP GeoffP is offline
Engineer
FRC #1222 (Falcons)
GeoffP is an unknown quantity at this point
with the new kit, the sprocket fits the shaft and just needs a key. if you need a spacer -- called a collar, I recommend metal tubing. measure your ID and OD to get your total difference, divide it by two to get the collar wall thickness. find the proper tube thickness or make it, then cut a slice out of the tube to make your ID match you shaft then assemble.
Unread 01-15-2007, 04:43 PM
None #2061
Yes, we have the key, but we're a little worried it won't hold, so better safe than sorry. What are the pro's for the meal tubing as opposed to plastic? As a rookie team, we really want to consider all our options. Excuse me, but what are ID and OD, please? (As I said before, we represent the word 'rookie' in all of it's forms!)
Unread 01-15-2007, 04:50 PM
Engineer
FRC #1222 (Falcons)
if the outside diameter (OD) of the shaft is the same size as the inner diameter (ID) of the sprocket, then there is no room for a collor or sleeve to fit in-between the two. The key fits into both and locks them from turning relative to each other. This is by far the best way to make the two mate together without slipping. if you need to make the sleeve, use metal on a drive spocket. the plastic will undergo to much force and will deform, fail, and slip. You can use a plastic sleeve if it is just a wheel to an axel or something.
good luck.
Unread 01-15-2007, 04:52 PM
None #2061
Oh, ok. Thank you for the help!
Unread 01-15-2007, 04:53 PM
Engineer
FRC #1222 (Falcons)
I just found your post on metal sleeve being out of you legue. Don't give up without a fight. you must be able to do this type of thing -- pick a guy and assign him to it.
Unread 01-15-2007, 04:55 PM
None #2061
We're a little nervous, but if we're going at this full speed ahead, we'd better try it out. Again, thanks!
Unread 01-15-2007, 04:57 PM
Billfred's Avatar
Billfred Billfred is offline
ID is Inside Diameter, OD is Outside Diameter. (For example, a ringer has an ID of 13 inches.)
My former team (1293) used metal spacers (of unknown origin) on the kit frame at the axles and PVC at the output shaft of the older kit transmissions*. Really, I didn't notice any particular advantage of one over the other. The metal tube we used was smaller and probably lighter than PVC, but PVC's cheaper and leaps and bounds easier to cut. Basically, use whatever's handier for you.
*I'm not sure what the recommended practice is for this year's transmissions.
Unread 01-15-2007, 05:03 PM
None #2061
So basically, it's all a matter of what sort of resources you have to draw from and of your personal preferences. Cheap would be a preference for us, though. Thanks Billfred
Unread 01-15-2007, 05:25 PM
in between teams
AKA: Luke Van Oort
Metal spacers are actually not too pricey. Just go to your local home improvement store and buy some metal tubing that fits. It can be cut with a tube cutter, hacksaw, a miter saw, and many other tools. However, I wouldn't recommend using a hacksaw, it is too easy to make a inaccurate, angled cut. We used aluminum pipe from Home Depot cut on a miter saw along with some plastic washers to hold our wheels in place in '06 and they held up fine as well as being pretty easy to make. We'll probably do the same thing this year.
Team 1219: 2009 - Mentor
Unread 01-17-2007, 01:04 PM
Dick Linn's Avatar
no team (Synergy)
We've used anything from plastic pipe to bronze thrust washers or bushings (cheap) to shaft collars. One time, a plastic cigar tube happened to be the perfect fit. At the end of a shaft, or for precise positioning, shaft collars work nicely. They are relatively inexpensive at MSC, and are available in aluminum or steel in one- or two-piece designs. I highly recommend having some around.
MSC shaft collars (starts on page 3817) http://www1.mscdirect.com/CGI/NNPDFF...0&PMT4TP=*LTIP
various bushings and washers (starts on page 3772) http://www1.mscdirect.com/CGI/NNPDFF...0&PMT4TP=*LTIP
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
[OCCRA]: Sprocket question? Mike Martus OCCRA Q&A 0 10-09-2006 12:30 PM
Sprocket FRC1710 Rules/Strategy 5 01-25-2006 03:08 AM
Sleeve on Fisher Price sanddrag Motors 4 02-06-2005 02:12 AM
I-sprocket? Daniel Brim Inventor 7 01-21-2004 07:26 PM
What is up Joe's sleeve nowadays? archiver 2001 3 06-23-2002 11:29 PM
