Go to Post FIRST: there is no second. - BandChick [more]
Unread 15-01-2007, 16:47
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: PWM 13-16 Replacement Code Beta Test
So... is the legality of this confirmed?
-Adam
There are no rules preventing teams from using this code, so there is nothing to confirm. If you're thinking that this somehow gets around the ability to safe motors, it doesn't because IFI's mechanism for doing that is under the master microcontrollers control.
-Kevin
Kevin Watson
http://kevin.org
Vex start up code run PWM outputs without Rx intellec7 Programming 3 05-05-2006 23:29
Pwm 11, 12 and CMU code Chris Bright Programming 3 01-02-2005 19:34
Victor Replacement JamesCH95 Electrical 4 15-12-2004 20:12
Replacement Parts archiver 1999 0 23-06-2002 22:01
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
