Go to Post According to a 6 year old I once met at a demo, our FRC machine was not a robot because, "How can it be a robot if it doesn't have a face?" - Jared Russell [more]
Unread 14-01-2007, 00:03
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
pic: Team #8's Robot Cad
Unread 14-01-2007, 00:05
dfukuba's Avatar
Technical Advisor
AKA: Daniel Fukuba
Re: pic: Team #8's Robot Cad
This is our CAD. It is in the ' weight class and can score on the top goal. Tell me what you think!
--Dan
Unread 14-01-2007, 00:07
Sean470's Avatar
Sean470 Sean470 is offline
FRC #0470 (Alpha Omega)
Sean470 is an unknown quantity at this point
Send a message via AIM to Sean470
Looks Cool.
Unread 14-01-2007, 00:08
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
What Danny is trying to say is thar our robot is in the 5' 110lbs weight class. The final bot will have the electronics on the piece of lexan in the middle, and have a camera mounted somewhere on the superstructure.
-Guy
Unread 14-01-2007, 00:15
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Looks good. The first thing I noticed was the 4 CIMs on planetaries, rather than a more traditional 2 motor gearbox. I also see a hole for a middle wheel, but it appears either to be unpowered or powered from two sides. Is there actually a 6th wheel or are you looking at a more exotic drive system (mecanum perhaps)? I like the manipulator, and I'll be curious to see it in action.
Unread 14-01-2007, 00:34
6 wheel drive train, the hole is for the bushing. The middle wheel is going to be lower, and driven by the planetaries. The arm still doesn't have motors modeled in too - probably looking at the window motors.
-Guy
Unread 14-01-2007, 00:59
run the trap!!!
Team Role: Human Player
Are you planing on rotating the "sucker" with a motor to allow for more easy acess to the HP loading station?
-Philip J. Fry
Unread 14-01-2007, 01:37
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
if you motorized your two input rollers for tube handling independantly of each other, you`d be able to rotate the tube as well as grab and release it.
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Unread 14-01-2007, 01:57
Richard: That's exactly how it's currently planned.
Martin: We're still thinking about it. Maybe.
-Guy
Unread 14-01-2007, 02:02
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Just a word of caution: Per <R12> - Robots cannot expand such that they no longer fit in a 72" x 72" x any height box, except in their own home zone.
It looks to me that if your robot is about 60" tall then that arm is probably also close to 60" long. So, If that arm swings to horizointal, will the robot still fit within the box? If not, it means that you can only swing your arm to horizontal in your own home zone. Then before you leave your home zone, you would have to raise the arm up high to make it fit in the box and only maybe score in the high spider and never bring the arm down until you got back to your home zone to get another ringer from the HP.
My suggestion: You can change your design just slightly so the pivot point of the arm up high is to one end of your robot. That way you can at least rotate it to all angles on the opposite side and still easily stay within the box. With this design you still cannot swing it to the same side as the pivot other than maybe to score on the high spider only. Good luck with your design. It looks very good and solid other than the flaw I mentioned above.
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 14-01-2007, 02:48
Raul - Thank you very much. We're now revising our design to acccount for the 72" x 72" limit. Expect something new pretty soon.
-Guy
Unread 14-01-2007, 17:06
KingBK's Avatar
KingBK KingBK is offline
FRC #1279 (Cold Fusion)
KingBK is an unknown quantity at this point
Looks simple so if anything goes wrong you'll be able to fix it.
Unread 14-01-2007, 17:08
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
I was just wondering how you are manipulating the tube. I was just thinking if you had those two rollers/wheels in the front of the grabber and you turn them in opposite directions will it spin the tube at the point you're holding it at?
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 15-01-2007, 17:31
sonofdad123 sonofdad123 is offline
FRC #0996 (Nerd-Uh-Knights)
sonofdad123 is an unknown quantity at this point
i like the grabbers that actually squinch the tube, rather than a grabber. why couldn't 996 think of this?? -cries-
nice design, which regional are you guys going to? we might be able to see y'all if you happened to mosey on down to the phoenix regionals.
Unread 15-01-2007, 17:44
We won't be in Phoenix, sorry. We'll be at Silicone Valley and maybe Vegas.
-Guy
pic: Team #8's Tube Interface dfukuba Extra Discussion 5 13-01-2007 02:04
pic: Team #8's Tube Interface dfukuba Extra Discussion 13 13-01-2007 01:16
pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing jfelser Extra Discussion 24 18-12-2006 21:18
pic: Team 759 CAD pic (almost finished) oljomo Extra Discussion 6 01-03-2005 16:31
pic: Team 356...Full CAD model CD47-Bot Robot Showcase 2 04-03-2004 08:08
