#15
Re: PWM 13-16 Replacement Code Beta Test
Most likely the PWM outputs from the user processor run through a buffer with an enable line, and the master disables the buffers when the robot is to be disabled, which tri-states the buffer outputs.
| Vex start up code run PWM outputs without Rx | intellec7 | Programming | 3 | 05-05-2006 23:29 |
| Pwm 11, 12 and CMU code | Chris Bright | Programming | 3 | 01-02-2005 19:34 |
| Victor Replacement | JamesCH95 | Electrical | 4 | 15-12-2004 20:12 |
| Replacement Parts | archiver | 1999 | 0 | 23-06-2002 22:01 |
| replacement gears | joni_m | Technical Discussion | 1 | 22-01-2002 18:01 |
