Go to Post Do I think the bar is too high? I think impossible dreams and lofty goals are a key part of FIRST; the "top" being extremely far away only pushes people farther. - Chris is me [more]
Unread 15-01-2007, 16:55
Ghosty Ghosty is offline
El Geeko Diablo
FRC #1357
Ghosty is an unknown quantity at this point
Tracking
I noticed that whenever the camera was tracking it was tilting downwards and then stopped tracking the green. Is this because I don't have a setting right for the noise filter or a value wrong for the RGB values. Any help would be great.
"Let's sing a song about safety, because safety is pretty important."-Bob the Ball
Unread 15-01-2007, 17:17
JSonntag JSonntag is offline
FRC #0486 (Positronic Panthers)
JSonntag is on a distinguished road
Send a message via AIM to JSonntag
Re: Tracking
If you are using Kevin's code, the way the camera is mounted matters. If you mount it with the on-off switch near the top, you have to go and change a few signs in your code or else it will always try to move away from the light instead of centering on it.
Unread 15-01-2007, 17:48
Re: Tracking
Here's what JSonntag is refering to in the code.
From tracking.h
// If your camera suddenly moves away from the target once
// it finds it, you'll need to change the sign on one or
// both of these values. Start with the tilt first.
#define PAN_ROTATION_SIGN_DEFAULT -1
#define TILT_ROTATION_SIGN_DEFAULT 1
Unread 15-01-2007, 18:03
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Tracking
See question nine: http://kevin.org/frc/camera/. It's best to rotate the camera 180 degrees. I've been trying to get 'em to fix that illustration for a year *sigh*.
-Kevin
Kevin Watson
http://kevin.org
Unread 16-01-2007, 10:53
El Geeko Diablo
FRC #1357
Re: Tracking
Thanks Kevin, your solution worked, I'm eternally grateful to your greatness.
Tracking Mr.Fahrenheit Programming 3 10-01-2006 21:50
Tracking in HyperTerminal cprogrammer Programming 2 20-02-2005 15:54
'tracking' flag zdeswarte Programming 3 20-02-2005 13:53
IR tracking nzj1 General Forum 3 26-01-2004 22:46
Tracking Wetzel Championship Event 11 06-03-2002 18:18
