Go to Post Then you might have a 1902 (oink oink BOOM) which could result in a 418 (Purple Haze). - JaneYoung [more]
Unread 15-01-2007, 17:23
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
Camera tracking problem
I've gotten the camera to work, and it is tracking the target, and everything is connected properly, but every time the camera locks onto the '07 Vision Target, it centers on the light, then tilts upward. It then centers back on the light. This cycle repeats. Should this happen or are one of the parameters incorrect?
Unread 15-01-2007, 17:26
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: Camera tracking problem
Are you using Kevin Watson's tracking code? You might have the vertical servo reversed; there is a parameter in Kevin's code that will change the sign, reversing the direction of that servo.
Good luck
JBot
Aren't signatures a bit outdated?
Unread 15-01-2007, 17:59
Kevin Watson's Avatar
La Caņada High School
FRC #2429
See question nine: http://kevin.org/frc/camera/
-Kevin
Kevin Watson
http://kevin.org
Camera Tracking Problem cprogrammer Programming 1 18-02-2005 15:00
Camera Only Tracking Green sybert1ger Programming 2 08-02-2005 20:21
CMU Camera Tracking auditt241 Programming 0 03-02-2005 16:33
Camera Tracking Woes VideoMan053 Programming 4 29-01-2005 18:09
Camera Auto Tracking? Ryan Cumings Programming 9 22-01-2005 02:20
