Go to Post Don't fix mechanical problems with software, ever. - Chris is me [more]
Unread 15-01-2007, 18:17
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: PWM 13-16 Replacement Code Beta Test
Originally Posted by Matt Krass View Post
I'm curious how that works, since the pins are supposedly connected straight to the user processor, how would the master processor disable that?
They aren't connected directly (which is why you can't use them as inputs). There is a switch that is controlled by the master that determines which processor gets to send its output to the pin. The call to Setup_PWM_Output_Type() tells the master processor who's in the driver seat (icky pun intended). When your 'bot is disabled, the switch is flipped to the master, which provides the 1.5 ms neutral pulse.
Edit: Actually, Dave's explanation may be closer to the truth. If the master is capable of generating the PWM output, why do we have the Generate_Pwms() kludge to deal with. Still, the 1.5 ms PWM neutral pulse needs to get generated for safety reasons. If not the master, who?
Also, how did you get around the interrupt-glitch thing? I'm missing something obvious when I look at the code...
The pulse doesn't glitch because once software sets up the timer and CCP hardware and says go, everything is done in hardware, which is oblivious to the interrupts firing-off in the background.
-Kevin
Kevin Watson
http://kevin.org
Vex start up code run PWM outputs without Rx intellec7 Programming 3 05-05-2006 23:29
Pwm 11, 12 and CMU code Chris Bright Programming 3 01-02-2005 19:34
Victor Replacement JamesCH95 Electrical 4 15-12-2004 20:12
Replacement Parts archiver 1999 0 23-06-2002 22:01
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
