Go to Post Another year, another picture of a Tytus injury. - Andy Baker [more]
Unread 15-01-2007, 18:25
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Banebot 64 to 1 on Spike?
Are the banebots motor gear box combo 64 to 1 allowed to be on a spike or do they have to be on a victor? Thanks
Faridodin "Fredi" Lajvardi KD7WKD
Unread 15-01-2007, 18:37
Re: Banebot 64 to 1 on Spike?
Rule <R92> says that only the CIMs and Fisher Price motors need to be connected to speed controllers.
Unread 15-01-2007, 18:43
AKA: Ledge
So by not mentioning the banebots that means they can be on a spike?
Unread 15-01-2007, 18:49
Gdeaver Gdeaver is offline
FRC #1640
This question is not directly answered on the schematic or manual. However, the current rating is above the spike capacity. They should be on victors. They could easily blow the spike fuse. Looks like this issue was overlooked.
Unread 15-01-2007, 18:50
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Yes they can be on a spike, but I would want them on victors. They only have forward/reverse or brake, I'm pretty sure they aren't variable though like victors.
Spikes are good for lights, solenoids, etc. I suppose if your motor was in a situation where it could be full forward/full reverse, then a spike would work, assuming that all other victors are used up.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 15-01-2007, 19:01
AKA: Dr. Brooks
no team (WRRF)
I would refer this to the QandA. The potential current draw of the
banebots motor is high enough that it should not be put it on a spike.
Unread 15-01-2007, 19:28
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by eugenebrooks View Post
I would refer this to the QandA. The potential current draw of the banebots motor is high enough that it should not be put it on a spike.
I agree this should be referred to Q&A. The Spike is rated for 20A continuously and 100A for 2 seconds. The RS-540 motor will draw 42A when stalled. So if you have the BaneBots gearmotor mechanically coupled in a way that could potentially stall the motor, you could potentially blow the fuse on a Spike.
If your mechanism is designed to run at constant speed whenever it is energized, and if you intend to used the Spike fuse as your means of stalled-mechanism protection, then per the current rules you might want to use a Spike. However, if you haven't thought about all this in advance you could experience difficulty diagnosing what went wrong when your mechanisms stalls and then won't work at all -- unless you remember to look for a blown fuse.
Richard Wallace
since 2003
Unread 15-01-2007, 22:12
AKA: Ledge
Thanks alot everybody! We will go with the victors!
BaneBot Transmission Encoder Daru Motors 9 27-01-2007 23:17
Banebot 2 motor adapter Ben Piecuch Motors 5 17-01-2007 16:06
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
