Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 15-01-2007, 22:09
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Must lifting mechanisms be behind the line
Durning the end of the game when you are lifting/or being lifted other robots does you entire mechanism stay behind the home zone line?
ex. if i have a ramp that streches out pass the line would it still be legal
Unread 15-01-2007, 22:18
GMAdan's Avatar
Re: Must lifting mechanisms be behind the line
Ok maybe i have to further explain i understand once in home zone you have no limit to expansion, but what if i had a ramp that when fully out was less than 72'' but the start of the ramp was pass the line but the robot wheels are inside. Would i still get points for lifting the other robots
Unread 15-01-2007, 22:26
GMAdan's Avatar
Well thank you all, i guess we will have to re-think how we are going to park in home zone.
Originally Posted by GMAdan View Post
...Would i still get points for lifting the other robots
It's the lifted robot which earn the points, not the lifting one. <G56> says the bonus is awarded to a robot if it is entirely within its home zone (and high enough, and not touching the field). The location of any robot not high enough to receive bonus points is unimportant.
Unread 15-01-2007, 22:28
Billfred's Avatar
Billfred Billfred is offline
That would be a different ball of wax. <G56> only talks about the robots being lifted. It doesn't say anything regarding the lifter, so I would interpret it as legal. You may want to have your expert submit a question to Q&A to be sure, though.
Unread 15-01-2007, 22:29
GMAdan's Avatar
o when reading the rules i didn't really look at like that, thanks. So i guess it wouldn't matter if the ramp was or was not in home zone as long as the lifted robot is
Unread 15-01-2007, 22:42
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Yes but your ramp cant be considered a wedge. Wedges can only be inside the home zone.
Like Aquidneck Island Robotics on Facebook!
Wrong! Two problems:
-Ramp: Outside of home zone, any surface more than 10 degrees from vertical is outlawed (<R05>). Your ramps may not leave the home zone while deployed.
-Size: If your ramp structure is longer than 6 feet in any direction (or is bigger that a 6'x6' box), you may not deploy it outside of home zone. You may be up to the size of the home zone, but only if you are completely within the home zone. (See Section 8.)
Unread 15-01-2007, 22:46
GMAdan's Avatar
you are correct, thank you all for helping me get to the bottom of this
B. Flaherty B. Flaherty is offline
AKA: Bill
FRC #1626 (Falcon Robotics)
B. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to beholdB. Flaherty is a splendid one to behold
Send a message via AIM to B. Flaherty
Originally Posted by <R06>
Ramps, platforms and other mechanisms specifically designed to elevate ROBOTS during the END GAME are exempt from Rule <R05> when they are deployed in the HOME ZONE. Such devices deployed outside the HOME ZONE are not covered by this exemption.
I hope this answers your question.
Boston Regional 2007 - Finalists (1626, 121, 1568)
Palmetto Regional 2007 - Finalists (1251, 1626, 1758)
Finger Lakes Regional 2009 - Semi-Finalists (1241, 229, 1626)
Unread 15-01-2007, 22:56
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
<R12> Once the match has started, the ROBOT may assume a PLAYING CONFIGURATION that
exceeds the size dimensions specified in Rule <R07>. While outside of its HOME ZONE, a
ROBOT may expand up to a maximum width of 72 inches and depth of 72 inches. While
entirely inside of its own HOME ZONE, there is no limit to the maximum width or depth of
the ROBOT, as long as it remains entirely within the HOME ZONE.
There are no height
limits for a ROBOT in its PLAYING CONFIGURATION at any time after the start of the
match (other than those naturally created by the ceiling height of the competition venue).
If the ramp bot exceeds the 72 inch foot print while outside the end zone, then it is in violation of <R12>. However, none of the "8.3.2 Robot Physical Rules" explain the penality for a violation. I would assume it should be a DQ. The question remains whether the alliance can get points for mounting a robot that is in violation of the Robot Physical Rules.
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
The secret behind this years game..... Adam Y. General Forum 1 31-03-2005 12:41
Stuff Behind the glass SpaceOsc General Forum 19 03-03-2004 13:42
Lifting the bridge...? archiver 2001 18 24-06-2002 00:41
Lifting Robots off of the Bar archiver 2000 24 23-06-2002 22:35
