Go to Post I am not short, I am just conveniently packaged. - kio_chan176 [more]
Unread 13-01-2007, 09:00
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
easyC PRO on Ubuntu Linux
I did a quick search to see if anyone has posted this before, and didn't really find anything besides a locked thread. Sorry if this information is already somewhere else.
I spent some time trying to get easyC PRO to work on Ubuntu tonight, and I thought I'd share how I got it to work.
* Note: I have not yet tested the USB/Serial adapter with this.
Screenshots:
Step 1: Get Wine 0.9.29 from here. Note that the compiler will not work with 0.9.22.
Step 2: After Wine is installed, download easyC PRO. Run the setup with the command wine /path/to/easyCPro.exe. This works mostly the same as on Windows.
Step 3: After you have easyC PRO installed, you can run it using wine "~/.wine/drive_c/Program Files/Intelitek/easyC Pro/easyC.exe"
Step 4: At this point, easyC should work normally with one problem - code will not compile. I'm not exactly sure if all of these things need to be done, but before I got it to work I did the following:
- Rename "~/.wine/drive_c/Program Files/Intelitek/easyC Pro/#Tools/Frc" to "~/.wine/drive_c/Program Files/Intelitek/easyC Pro/#Tools/FRC"
- Rename "~/.wine/drive_c/Program Files/Intelitek/easyC Pro/#Tools/FRC/Api" to "~/.wine/drive_c/Program Files/Intelitek/easyC Pro/#Tools/FRC/API"
- Rename "~/.wine/drive_c/Program Files/Intelitek/easyC Pro/#Tools/FRC/API/Api.h" to "~/.wine/drive_c/Program Files/Intelitek/easyC Pro/#Tools/FRC/API/API.h"
- I'm still not sure on why this part had to be done:
Edit API.h and remove all of the VEX parts from it, and all of the #ifdef _FRC_BOARD and #endif lines associated with them. I'm guessing the compiler may have freaked out with the line breaks on those, but I really don't know. My copy of API.h that is working is attached.
I think that's it, but I messed around with this for quite a while so I might have missed a step or two.
Hope this helps.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 15-01-2007, 22:58
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: easyC PRO on Ubuntu Linux
Nice job guys now you just need to get it working in OSX.
Unread 16-01-2007, 02:22
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Fire up Parallels, fire up easyC, click Coherence, hide the start bar
What place are we at? ... TODAI!
Unread 16-01-2007, 09:00
Kingofl337's Avatar
AKA: Adam
Yeah, thanks sport I didn't figure that out.....
Mac users can also use boot camp.
I idea is to run inside OSX without purchasing Paralles and then XP.
Unread 09-04-2007, 19:17
Athena Athena is offline
FRC #1676 (Pi-oneers)
Athena is on a distinguished road
hi. i just installed easyC pro with the newest version of wine, version 0.9.33. it installed it differently. the command to run it is wine "C:\Program Files\Intelitek\easyC Pro\easyC.exe" i just compiled some code just fine. so idn. maybe there is a problem with wine .29? i didn't have to change any file names. So hopefully the code loads alright. I guess I'll find out in atlanta
Unread 10-04-2007, 19:31
Kingofl337's Avatar
AKA: Adam
We have a new version of easyC Pro / V2 coming out that changes the way easyC compiles it should if anything make it easier to make easyC work in wine. The fix was for non-us versions of windows but I feel it will help linux users. Keep an eye on the Pro website.
Download easyC PRO & 2007 Kickoff Code Kingofl337 Programming 1 24-01-2008 09:15
Additional easyC Pro License Dung H Cao Programming 2 10-01-2007 14:45
pic: intelitek's present to you.....a sneak peek at easyC PRO! Jessica Boucher Extra Discussion 22 02-01-2007 14:06
pic: easyC PRO at work! Jessica Boucher Extra Discussion 12 14-12-2006 15:25
