Go to Post I once started to build a time machine. But then I went back in time and told myself that it wouldn't work, so I gave up on it. -dave - dlavery [more]
Unread 16-01-2007, 09:48
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Camera servos too slow, help please
Try these:
- disconnect the servo linkage so the servo shaft is free and see if the unwanted motion continues. If it doesn't, the servo shaft was probably rotated too far when you pressed the round plastic servo arm onto the shaft, and your code is trying to drive it past the internal stops.
- try a different PWM cable
- try a different servo
- if your PWM cable is very long, it might be picking up electrical noise - use a clamp-on Ferrite core to solve this (similar to Digikey 445-2038-ND) http://www.tdk.co.jp/tefe02/e9a15_zcat.pdf. You might find something similar at Radio Shack.
Unread 16-01-2007, 10:17
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
That reminds me of how I "tared" our camera servos. I plugged them into the RC before building the camera mount, then set the pan servo to PWM=124 and the tilt servo to PWM=144. (These are the default center values in Kevin's cam code.) I then removed them from power so they'd stay in that position and built the cam mount.
Since you already have the mount built, if you think setting resetting the servos to allow more useful angle might help, just remove the retainer screws on the servos and lift the "PT-HORN" off. Then you'll probably want to remove the whole PT-MNT piece also. Then run code to set the PWM values I said above, remove power, and add the PT-MNT at whatever angle you want and rotate the PT-TILT-BRK however you want. Press them back onto the servos and replace the retainer screws.
(I got the "PT-HORN" type names from the official Mount Assembly instructions)
What place are we at? ... TODAI!
Unread 16-01-2007, 13:16
Lablabla Lablabla is offline
AKA: Carmel Barak
FRC #1957 (LighTeam)
Lablabla is an unknown quantity at this point
Thank you all,
I will check it out tmw at school and let you know how it worked
LighTeam #1957
2006 GM/Technion Israel Regional Finalist (Robot: W.Bob)
Attending: Israel GM\Technion Regional (Robot: Laika)
Unread 18-01-2007, 08:00
AKA: Carmel Barak
Well,
I've done that, and during the search mode it did infact moved faster.
but when it spotted the green light, its movement were so slow we could bearly move the target without the camera losing track of it
Any ideas?
Thanks,
Carmel
LighTeam #1957
Unread 18-01-2007, 12:04
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Lablabla View Post
Well,
Any ideas?
Thanks,
Carmel
The servos can't generate a lot of torque, so make sure you built the pan/tilm mechanism per the instructions and didn't over-tighten the fasteners. You'll need to disconnect the servo from the linkage to see how freely it moves.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2007, 11:59
AKA: Carmel Barak
Hi,
I don't think so,
cause when we checked for momvment using the joystick, the servos moved great, and also in the searching mode they move great. only when it spots the light it slows down.
Carmel
LighTeam #1957
Please help. I've had it with this camera Inverted Programming 6 14-01-2007 22:35
Premiere won't recognize camera - please help sanddrag IT / Communications 9 04-01-2007 20:17
please help me to plag in the camera CompMaster Programming 1 16-02-2006 11:24
Kitbot/cims/transmissions running too slow? Swampdude Technical Discussion 28 23-01-2005 11:17
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
