Go to Post GP isn't just a good idea, it's mathematically optimal. - Jared Russell [more]
Unread 15-01-2007, 23:13
TJ4nier TJ4nier is offline
Professional Stress Monger
AKA: TJ
FRC #2168 (Fitch CyberFalcons)
TJ4nier is an unknown quantity at this point
Send a message via AIM to TJ4nier
Servo Strength
How much weight could one of the servos from this years kit hold? The part of our robot that I'm assigned to requires a servo to hold it still until told otherwise, but I'm not sure if that will work considering the size of the part compared to the servo.
But, hey, maybe it has some hidden strength deep within that teeny little black box?
Professional Graciousism?
Gracious Professors?
Profess Graciousness?
No. Listen to the "W-Dawg" Flowers!
It's GRACIOUS PROFESSIONALISM.
Unread 15-01-2007, 23:37
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Servo Strength
http://www.servocity.com/html/hs-322...rd_deluxe.html
Says its got 51 oz/in of torque
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Servo Strength
The servos provide 42 oz-in of torque, which is relatively low compared to a high torque servo, but it still may be adequate, just depends on how much you gear it down
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 15-01-2007, 23:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Servo Strength
The servos are rated at about 40 oz-in holding torque. Not a heck of a lot. Their typical application is moving RC airplane control surfaces or steering RC car wheels.
Unread 15-01-2007, 23:41
AdamHeard's Avatar
Lead Mentor
Re: Servo Strength
You could have the servo hold a pin that holds the load.
We used a servo in 2004 to hold back the force or two arms on surgical tubing pivots to hang. It was difficult to pull by hand and the servo had no problem holding the pin that let them go.
Unread 16-01-2007, 00:23
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Re: Servo Strength
Dont forget that while yes the servo may have 42 oz/in of torque, if it the piece its supporting gets jarred or knocked you will strip it out easily. I dont know if they are allowed but you can buy beefier servos with brass gears in them. Hope this helps.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 16-01-2007, 00:31
Re: Servo Strength
Not allowed to use other servos, as far as I know.
Unread 16-01-2007, 00:37
amos229's Avatar
Retired chicken man
AKA: amouse
Re: Servo Strength
[quote=EricH;557922]Not allowed to use other servos, as far as I know.
I was not sure, dial up is to slow to download manual
Unread 16-01-2007, 00:38
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Servo Strength
from a previous robot, don't allow servos on surfaces that can be moved by grav ity/bad humans/etc, as they WILL strip out quickly.
Unread 16-01-2007, 11:02
Electrical Engineer
Rookie Year: 1995
Re: Servo Strength
This has got to be one of the weakest excuses I have ever heard for not reading the manual.
I have dial up... Always have...
As of 2006, 44% of internet access is dial up (J.D. Power and Associates 2006 Internet Service Provider Residential Customer Satisfaction Study).
If 44% of teams did not read the manual because "all they have is dial up", FIRST would fail miserably.
JMHO.
Mike
Mike Betts
As easy as 355/113...
Unread 16-01-2007, 11:16
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
Re: Servo Strength
You limited to 2 servos for the entire robot so using a servo in another postition will leave you without the pan and tilt mechanism provided in the kit. This may or maynot be acceptable for your team.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
Unread 16-01-2007, 11:19
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Servo Strength
PID and encoders/pots anyone?
Can give you some help to get started if you need any... just gimme a pm/email/post.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 16-01-2007, 11:27
Re: Servo Strength
That may have been true several years ago, but this year <R45> specifically allows additional HITEC HS-322HD Servos.
The FIRST manual used to specify that servo manufacturers typically inflate torque rating to double the actual value. So, take the 42 oz-in with a grain of salt.
Unread 16-01-2007, 11:56
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Servo Strength
Oh, really? Can you cite the specific rule that limits you to two servos?
-dave
p.s. then read <R45>.
Unread 16-01-2007, 14:22
ewankoff's Avatar
AKA: -=The WANK=-
Re: Servo Strength
Im sorry i was under the impression that this rule had not changed. I guess skimming some of these rules is not a good idea. Ill go back to read every single rule word for word.
Palmetto finalists
Championship Division Strength Rob Championship Event 26 06-04-2006 18:19
Strength difference between aluminum sdcantrell56 Technical Discussion 3 21-01-2006 10:07
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Strength of welds on gears sanddrag Technical Discussion 16 30-01-2004 17:32
shear strength Andrew Dahl Technical Discussion 1 14-02-2002 10:02
