Go to Post I believe you have the right to develope your own opinion. I would suggest it be based on actual experience and facts. - Mike Copioli [more]
  #31   Spotlight this post!
Unread 16-01-2007, 09:12
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: "Smart" Breaker Panel Acceptable for '07?
Originally Posted by whytheheckme View Post
Can we use 2 maxi blocks?
We have 5 CIM motors total (4 small and 1 large) on our robot, but the MAXI block only has 4 40 amp breakers. The Panel allowed for use of 6; does this mean I need a WHOLE OTHER chunk-o-brass to power just one motor?
Jacob
You could run the larger CIM off a 30A breaker from the ATC panel .. the stall draw on the large CIM is 40A lower than the smaller CIM, and peak power is 70w less. Not too sure the risk of tripping the breaker, it'll depend on how hard that motor is being ran.
I recall seeing teams from previous years using smaller (1 and 2 port versions) of the MAXI block. The terminal supply co PDF catalog isn't cooperating with me this morning, so I couldn't see if it still existed.
But you are allowed to run another heavy MAXI block if you want.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
  #32   Spotlight this post!
Unread 16-01-2007, 09:29
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Cool. 10 minutes ago when I thought that I would need another 4 port MAXI block I could just see my (robot) weight management guy cringe....
I'll look for the 1 or 2 port MAXI... This could be really useful. Our large CIM is driving the whole *elevator* of our robot and needs to be able to lift quite a bit, so I think I'm going to stick with 40 amps.
Thanks for the help,
Jacob
  #33   Spotlight this post!
Unread 16-01-2007, 11:57
Jacob
<R45> Items specifically permitted on 2007 FRC ROBOTS include:
One additional 4-slot Maxi-block circuit breaker panel and utilize it on their 2007 ROBOT in addition to, or in replacement of, the circuit breaker panels provided in the Kit Of Parts.
Sorry,
There is no other alternative. Ask this on the Q&A as I suspect they may be lenient in the use of single or dual versions of the Maxi block.
"If Robots Get too Smart..." RoboMom Chit-Chat 9 07-06-2006 01:10
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
60Amp Circuit Breaker Mounting "Experience" archiver 2001 0 23-06-2002 23:57
