Go to Post In real life (IE when you go to apply your engineering skills to tasks in industry) there will be constraints on all sorts of things - many of which may or may not be "fair" or even "intelligent". You must learn to either work around them or use them to your advantage - preferably a bit of both. - OScubed [more]
Unread 16-01-2007, 13:36
Nate Laverdure's Avatar
FRC #2363
pic: Ringer Supported by Both Spider and Stinger
Unread 16-01-2007, 13:37
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
Re: pic: Ringer Supported by Both Spider and Stinger
I believe that it does not count, i remember reading that the ringer must be fully supported by the spider leg. But if someone else finds otherwise, please post.
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 16-01-2007, 15:14
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Good question! The relevant Game Definition for HANGING is "...its' weight is fully supported by a SPIDER LEG...". In your example you could make a case (albeit a rather reaching one) that the RINGER is at least partially supported by the STINGER. However, in the real world of FIRST, I think that the referees would call it scored if the RINGER is touching the SPIDER LEG.
Pete Kieselbach
Unread 16-01-2007, 15:21
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
I have noticed the tubing first had was alot stiffer then the stuff they told us to buy.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 16-01-2007, 17:24
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Where are you guys hiding this (partial) rack? I was there this morning, and I didn't see this.
Unread 16-01-2007, 18:49
FRC #2363
This is 122's rack, not 612's. I'm at ODU in Norfolk, and I'm helping out 122 (NASA Knights) in Hampton.
Unread 17-01-2007, 08:37
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
does anyone know the dimentions of the stinger? we tried to find it but failed.
Unread 17-01-2007, 15:45
FRC #2363
The stinger sticks out 4" from the top of the end plate. Look at the rack sub-assembly documentation (http://www2.usfirst.org/2007comp/Dra...emblies_R-.pdf) for more info.
pic: Full Scale Prototype Ringer Arm 2007 lynca Extra Discussion 5 20-01-2007 00:25
pic: Test Rack Stinger Detail MrForbes Extra Discussion 14 09-01-2007 22:39
pic: 2 ringer spacing Ryan Foley Extra Discussion 3 07-01-2007 01:31
pic: Spoiler and Ringer on top leg 2 Ryan Foley Extra Discussion 1 07-01-2007 01:25
