Re: Green light Case
Thanks!
That's exactly what I was looking for Thanks for the hint ![]() EDIT: Now that I look at this, it looks as if the casing is something we should have got in the kit of part. is it? or we need to built this one? Last edited by Lablabla : 16-01-2007 at 14:10. |
you get the cold cathodes and the front lens in the kit......you have to build the rest from tinfoil covered wood or aluminum.
/forest |
Alright,
How do you power this thing? while it out of the box, no problem, 12 volt power source, but when in the closed box? |
i would make a terminal block on the inside of the box. then wire all of the CCs to that and then attach a length of wire from the terminal block to a battery or even better a 12v power supply (old computer power supply)
also dont forget t add ventilation holes in the box.....the CCs and their transformers will get warm.![]() /forest |
thanks,
another question I'm looking at the pdf file for a long time, trying to understand to final mesurements of the complete box 16"X8"X??? 1" as seen at square #3? what's that aluminum block? (#22) and what's the aluminum angle (#26) Thanks, Carmel |
How many lights do you need to put in the box? We only have 4. The drawing shows putting 8 lights in it.
Some kid last year thought the lights were to make the robot look like a low rider. Brian |
#7
there should be 8 light, in 4 boxes (2 in each, duh)
#8
We just velcro'd the CC's to a block of wood. Used a peice of black plastic (The 80/20 stuff) as the back, and used the wood as standoffs for the lights. Then I used standoffs (similar to those in your computer holding the motherboard, but longer) to hold the HDPE lens away from the CCs. It's pleanty bright, the camera sees it fine. No alum. foil involved
| Green light same color as overhead light | Ethulin | Programming | 13 | 02-08-2007 15:24 |
| camera trouble,cant tell the green-light from regular white light | Nimmy | Programming | 26 | 14-01-2007 14:53 |
| KOP green light | 987HighRoller | Kit & Additional Hardware | 1 | 13-07-2006 23:18 |
| pic: Green Light | Dermot_135 | Extra Discussion | 17 | 19-01-2006 18:02 |
| Green Light | Rachika Garcia | Kit & Additional Hardware | 1 | 10-01-2006 08:46 |
