Go to Post [Programming a swerve drive] It's really really simple, unless you actually do it. - Ether [more]
Unread 16-01-2007, 15:37
Lablabla Lablabla is offline
AKA: Carmel Barak
FRC #1957 (LighTeam)
Lablabla is an unknown quantity at this point
Re: Green light Case
thanks,
another question
I'm looking at the pdf file for a long time, trying to understand to final mesurements of the complete box
16"X8"X???
1" as seen at square #3? what's that aluminum block? (#22)
and what's the aluminum angle (#26)
Thanks,
Carmel
LighTeam #1957
2006 GM/Technion Israel Regional Finalist (Robot: W.Bob)
Attending: Israel GM\Technion Regional (Robot: Laika)
Unread 16-01-2007, 16:43
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
How many lights do you need to put in the box? We only have 4. The drawing shows putting 8 lights in it.
Some kid last year thought the lights were to make the robot look like a low rider.
Brian
Unread 16-01-2007, 17:12
AKA: Carmel Barak
there should be 8 light, in 4 boxes (2 in each, duh)
LighTeam #1957
Unread 16-01-2007, 21:53
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
We just velcro'd the CC's to a block of wood. Used a peice of black plastic (The 80/20 stuff) as the back, and used the wood as standoffs for the lights. Then I used standoffs (similar to those in your computer holding the motherboard, but longer) to hold the HDPE lens away from the CCs. It's pleanty bright, the camera sees it fine. No alum. foil involved
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
KOP green light 987HighRoller Kit & Additional Hardware 1 13-07-2006 23:18
pic: Green Light Dermot_135 Extra Discussion 17 19-01-2006 18:02
Green Light Rachika Garcia Kit & Additional Hardware 1 10-01-2006 08:46
