Go to Post you must do whats best for the company...not yourself. - Greg Perkins [more]
Unread 15-01-2007, 23:11
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: The best joystick?
I prefer the Logitech gamepad. However, if I had to pick a joystick it would be the Logitech Attack 3. It's mechanical resistance is very consistant throughout it's range. It' ergonomic shape and smooth transitions about its full range of movement is very pleasing to the hand. Also, it tends to rebound to its center quite consistantly.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 16-01-2007, 15:40
Ian S. Ian S. is offline
FRC #1522 (D.O.T.M Robotics)
Ian S. is an unknown quantity at this point
Send a message via AIM to Ian S. Send a message via Yahoo to Ian S.
Team 1522 is currently testing the X box 360 controller using the USB chicklet F.I.R.S.T introduced this year. Although the sensitivity will be much higher, we most likely will use them for the competition this year. Since my team is also using mecanum wheels (85% sure), having 2 "joysticks" on each 360 controller is very handy.
D.O.T.M - Defenders of the Multiverse
2006 VCU Regional Finalists (thanks to team 345 & 384)
2008 VCU Regional Champions (thanks to team 345 & 1086)
Unread 16-01-2007, 16:35
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
We're also planning on using the XBox 360 controller using the USB chiklet.
-Guy
Unread 16-01-2007, 17:15
lord Purity lord Purity is offline
FRC #4119
lord Purity is an unknown quantity at this point
I believe the best joy sticks to use would be basically PS2 style COntroller, becuase it has two joysticks with one controller, with more range to use it such as the left joy stick to use for forward and reverse while the right to for right and left
Best Joystick ? Seared Ice Control System 19 27-05-2005 00:05
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
Reversing the joystick axis JBotAlan Programming 3 09-02-2005 19:47
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
Pin-outs for the joystick? MADCOW Electrical 3 29-01-2004 17:31
