Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 16-01-2007, 16:03
Alex G Alex G is offline
FRC #0201 (FEDS)
Alex G is an unknown quantity at this point
Re: 2 Cmucams?
Originally Posted by Kevin Watson View Post
I don't choose to argue about anything. I'm right and you're wrong. The serial data from the camera generates just over one hundred interrupts per second, not "a few thousand" and certainly not "11520".
-Kevin
You're right. I believed that the data packets were larger, but after checking the code carefully I found that I was wrong. Sorry if I seemed too jumpy.
