Re: Team Update #3 Posted
That'd be interesting.. maybe using lifesavers for ringers, although I don't think we're allowed to bring edible objects onto the field.
The way I see it, this now allows for brining laptops out on the field, if their wireless connection is disabled. A laptop doesn't connect to the OI, field, r another member, would not have wireless communication, and doesn't affect the outcome apart of strategy. Sweet!
-Guy |
because it says it can't touch the "field" so i guess it depends on your definition of field. I would count the driver station as part of the field. and using a laptop with one hand is no fun. my opinion: tablet for the win! ![]() Last edited by AV_guy007 : 16-01-2007 at 19:04. Reason: capitalization |
I agree that a tablet is the best option for keeping track of real time scores. However, I think that having a tablet is amazingly expensive, and most teams will have to settle for some sort of paper-based solution instead.
Or place your Laptop on the ground and use a USB tablet, mine was a nice 6x8 and only cost 50 bucks on newegg
#7
For those with racks assembled.. can you actually see to the other side of the rack, from the driver station position, to know what legs have been scored on? Are you assuming the opposite end of the rack will be scored on before the one directly in front of you? If an opposing team were to do a counter move on the less visible side of the rack, while the rack was reasonably full, with innertubes, are you able to tell?
#8
thats true... But I just got an amazing idea, get/make those things that the snack guys carry all the snacks in at baseball games, hang it around your neck and put your laptop on it.
#10
In the heat of a match, to look away from the field could prove disorienting and costly.. especially when you have to reframe your brain to fiddle with graphic screens, touchpads, or keyboards.. you may forget what you are doing, or miss some important event on the field. I'd say find a better way.
#11
That is crazy talk ![]() One of the members on our team already made a palmpilot app. for scoring calculations, and all he needs to do is press two buttons to place a tube on the virtual rack. The program even tells the score of each alliance, and he is working on a 'Next best Move' algorithm... Which is MUCH easier than a pencil and paper or dry-erase board. There is absolutely no reason to use Paper/Board when you have access to a palm-pilot, Its only purpose is to detract from the usefulness of your coach. |
#12
A friend of mine tried to do that so he could have his laptop when he walked around outside and went places. It didnt turn out to well and he constantly had to look up and see he didnt run into things. But that wount be an issue for this case.
#13
Board and marker or paper and pad.
#14
would there be a way to get a wired connection to the feed on the big screen on a laptop?
that could possibl seeing the other side of the rack |
#15
It can prove to be an advantage sometimes, but most regionals that have big screens have multiple cameras/ camera angles so it will be very ineffective. But it could help. |
| Team Update #2 Posted | Billfred | Rules/Strategy | 4 | 15-01-2007 04:00 |
| Team Update #2 is Posted | geo | General Forum | 1 | 16-01-2004 10:56 |
| Team Update 8 Posted! | Harrison | General Forum | 1 | 30-01-2003 08:08 |
| Team update #6 posted | Joe Ross | General Forum | 6 | 22-01-2003 10:14 |
