Go to Post A Mentor is.. A person you can talk to anything about and trust them to not throw it back in your face in any way shape or form and who will help you as much as they can to deal with the problems and situations in life... - Elgin Clock [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-01-2007, 21:32
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: How many targets?
Actually, the team update states:
Originally Posted by FRC Team Update #1
Kit of Parts Checklist_RevC includes the following changes:
Each team should have received two of the target light boxes (16 bulbs, 8 transformers),
but only one was shipped with each kit. We are in the process of shipping the additional
target light kit to each team. FIRST apologizes for the error.
Unread 11-01-2007, 12:10
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
You got it. It looks as though no way to "see" 2 targets at once.
Originally Posted by Lostmage333 View Post
If you think about it, there is no angle at which you can see more than 2 of the lights at a time. Therefore i don't think FIRST thinks we need more than those yet. I believe they will be avalible for purchase through FIRST eventually, and they can be bought elsewhere.
Like Aquidneck Island Robotics on Facebook!
Unread 11-01-2007, 14:32
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Yes, you absolutely CAN see two lights at once. You just cannot see MORE than two lights at once.
-dave
Unread 11-01-2007, 14:36
Elgin Clock's Avatar
FRC #0237 (Black Magic)
-dave
Well... you CAN see 2 lights plain as day at once, and if I recall correctly the other 2 (actually all of them) have the vent holes for heat in them in the back.. so.. I guess maybe if you calibrate it to the highest sensitivity, you have a chance of seeing light through the back of the targets and that hole pattern right?
Tha again maybe not and this is just a wicked stretch of the abilities of the cameras.
Unread 16-01-2007, 18:16
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Actually, you can easily get into a situation where 2 lights will visible at the same time. However, the odds are slim that you will only be able to see one (Depending on initial robot placement).
To assemble the light box, you should use 4 cathodes in pairs of 2 and 2 transformers. Thus the 8 cathodes that shipped in the KOP could be used to build 2 targets through that configuration. Someone above me complained about that halving the brightness, but I don't think that that should be a problem. One of these cathodes is pretty darn bright.
The "official" assembly uses a whoping 8 cathodes! I don't see why they would need that much. I designed my cam code only using 2.
See this link: http://www2.usfirst.org/2007comp/Dra..._TARGET_R1.pdf
But APPARENTLY, some nincompoop at FIRST only gave us 1 box of 8 and were supposed to give us 2. So as of right now you can build only 1 regulation light box and wait for the new 8 tubes to come in the mail.
I quit FRC over 2 years ago (more if you're reading this past 2010).
how many of what? Hendrix Motors 1 11-02-2005 13:19
How many SD teams in 05? JP_1163 FIRST-related Organizations 0 01-10-2004 11:50
How many Attwoods? mike325 Technical Discussion 0 06-01-2003 17:43
How many robots? archiver 1999 1 23-06-2002 21:54
