Does anyone know of a good way to attach the wheel and the gears together and then get them attached to the motor?
Pics and or directions would be very helpful. |
Re: Wheel Designs
Depends on the wheels you're using. If you're using solid wheels, drilling holes in accordance to the bolt pattern of a specific kind of sprocket would be your best bet, with some polycarbonate, wood, carbon fiber, or any other material spacer to fit. Then, just bolt the sprocket on to your wheel, and that's one half of the equation.
For the other side, the BaneBots GP-56012 (The 56mm, 12:1 Planetary single motor gearbox that comes with the kit) has a nifty 1/2in wide, 4in long driveshaft with a nice little notch in the shaft that is .125in deep. That notch, which runs down the length of the shaft, can be used to hold a sproket with one of those small hex bolts in it. Hope this helps. -Otaku |
Re: Wheel Designs
yes it does. thanks
Last year we just put gears on the motor shaft and the axels of the wheels. Then we connected them by using a bicycle chain to connect the motors and wheels. Hope that helps a little.
Re: Wheel Designs
I'm also pretty sure that despite the weight, most teams will go with a chain-drive system. Thanks for adding in that little bit, though. I forgot to mention that you link it with chain. |
Re: Wheel Designs
Attach the bigger sprockets to the kit wheels with 8-32 nuts and bolts (get these from a hardward store). Then attach the small sprocket to the output shaft of the transmission. Secure it to the shaft with shaft collars, or get some new sprockets with set screws built in. Then run your chain from sprocket to sprocket, lay it out and make a mental mark of what link will connect the two, with some slack. Break the chain and connect the two halves with a master link, and you're set.
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 17-01-2007 01:21 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| Tri-Wheel Designs | Ben Piecuch | Technical Discussion | 3 | 30-03-2004 13:03 |
| Steerable wheel designs | Max Lobovsky | Technical Discussion | 3 | 08-02-2004 14:13 |
| 2-wheel versus 4-wheel drive | Ben Mitchell | Technical Discussion | 23 | 07-11-2003 00:50 |
