Go to Post Yes, it really is Bill Miller posting on Chief Delphi (Imagine that!). - Bill Miller [more]
Unread 16-01-2007, 18:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: CMUCam over programming port problems..
Originally Posted by 114Klutz View Post
Here's my current configuration - I have the CMUCam2 connected to the programming port with a M/M Serial Cable. Over the TTL connection it works perfectly, however, over the programming port, it doesn't. The servos center, the lights are on, both of them, on the CMUCam2. This is normally indicative of no camera signal.
I connected the programming port to my laptop, and ran a terminal program. I repeatedly received the CR?>, which I assume to mean camera ready? message. I am not receiving anything else, such as printf debug messages; so that can not be the cause of failure. I have tested the camera over the serial port with the java application, it also works fine.
I'm out of places to look, I reset the robot controller multiple times, and the voltage on the backup battery was 8.2 volts. I went through the FAQ already.
If you want, zip-up your code and send it to me and I'll have a quick look this evening.
-Kevin
Kevin Watson
http://kevin.org
Programming for CMUCam teh_pwnerer795 Programming 6 25-12-2006 00:23
CMUCam TTL problems gabrielse Programming 4 13-02-2006 14:07
COM port settings for CMUcam labview testing and programming pwilczynski Programming 1 15-01-2006 15:09
CMUcam 2 problems KChampion Programming 1 07-06-2005 10:39
CMUcam autonomous programming kshot Programming 1 17-01-2005 19:18
